You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
you are suppose to turn it all the way to the left past off. then put a paper clip or wire in the hole and press a small brass button. then turn
the key left some more. it then pulls out. however my 63 had two holes
and would not go past off. the brass ball is on the rim next to the
lock mech. i had to get jungle with mine. it finally pulled just the outer
trim off. then i pressed the brass ball. i was lucky my napa dealer which never has any stock had the switch and lock mech for a 63. just did this
friday when smoke started coming out of my speaker area. switch started
to melt the black plastic wiring harness on the back. jim
Location: The problem is all inside your head she said to me.
Thanks I'll look for the hole. Don't remember it but will look again.
There should be a small hole in the face of the switch. Insert a paper clip n that hole and with the key in the switch turn it to the left {accessory position} and it should come apart. To put it back together reverse the procedure....I use to do it for customers all the time and I think the above is the correct way.
