Cheap Wheels For The Body Shop
Before I cart my '65 to the body shop, I want to pull off the knock offs and put on a cheap set of used wheels. What wheels are easy to find and will fit a '65 with 4 wheel discs? Thanks
They should clear just fine. I have one of the S-10 mini spares for my C2. Get one from a junk yard and try it on for size. I used mini spares while building my 32 Ford and they worked great.
How "mini" are they? It is a twenty mile drive to the body shop. Would these be safe?
2018 C1 of Year Finalist
Why not buy wheel dollies? 100.00 from northern or harbor freight. Unless you do not have a set of wheels. S-10 spares will work u can take off the calipers if you need to. I used 14 x 5s on my c1 with trailer tires and it worked well.
I would get some real wheels then you would always have them as a back up. You can possibly cut a deal for wheels with tires already mounted. For the temporary situation in the body shop I think wheel dollies are a great idea....keeps the body techs from running out to pick up lunch at Taco Bell in your car too..
