C1 Trunk Lock
Old 03-21-2010, 06:00 PM
Pierre
Pierre's Avatar
Default C1 Trunk Lock
The trunk lock on my ’56 has always worked just fine. Yesterday I opened the trunk for the first time this year and it opened OK, as it always has. This morning, I went to open the trunk, but now for some reasons, the lock just won’t turn. The key goes in all the way smoothly but the lock wont turn. Same problem with all spare keys. I tried to push down on the lid a bit but that doesn’t help.
Any suggestions for this PITA problem?
Pierre
Old 03-21-2010, 06:07 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,084 Likes on 4,737 Posts
Army
I'm assuming the car is indoors and the lock is not frozen from the cold (taking into account your Northern location!).
I have had some luck once in a while forcing the tip of the key part way into the lock to open the little 'flip door' a ways and then squirting a shot of penetrating oil into the lock mechanism. Do NOT get the fluid on the paint. Work and jiggle the key around and maybe you'll get lucky...if no joy with this method you may have a broken piece in the trunk lock (bad news) and maybe its locksmith time.
(I don't know another way into the trunk of a C1, unlike some modern cars where you can crawl in by removing the back seat).
Old 03-21-2010, 07:01 PM
Pierre
Pierre's Avatar
Thanks for your response Frank. I have actually squirted some WD40 in the lock with the small tube that comes with the WD40 spray can. It feels just as if I was using the wrong key, but all four keys can't be wrong. The car is always kept inside and it's quite warm here today, so freezing isn't the problem.
Pierre
Old 03-21-2010, 08:13 PM
Ironcross
Ironcross's Avatar
you are using the ignition key to open the trunk, right?...as that is correct
maybe not for a 56 though
Old 03-21-2010, 08:58 PM
62Jeff
Support Corvetteforum!
62Jeff's Avatar
I don't know if the same can be said for a 56 (I don't suspect so) but on my 62 I once had to punch out the trunk emblem with a screw driver and hammer, so that I could get my hand into the trunk and access a failed trunk lock.
Old 03-21-2010, 09:36 PM
babylonvette
babylonvette's Avatar
i was lucky enough to lock my keys in the trunk once,i was able to get a long thin steel rod and ducktape a screwdriver to it ,open the conv hatch and go thru the hinge tower it only took a few minutes,aim the srewdriver for the latch and insert where the lock linkage goes thru and turn it was actually very easy,i thought about punching out the emblem but the car was just painted and i was afraid of ruining the trunk or paint
Old 03-22-2010, 09:10 AM
kenmo
kenmo's Avatar
Good tip...
Old 03-22-2010, 09:33 AM
Pierre
Pierre's Avatar
Thanks, have to give that a try....
Pierre
Old 03-22-2010, 09:47 AM
C-1 Generation 2
C-1 Generation 2's Avatar
I know it doesn't apply to a 56 but on the 61/62 you could probably remove the license plate light assembly and unlock the trunk through there.
Old 03-22-2010, 10:12 AM
Frankie the Fink
Army
Really ? Not saying it isn't so but that sure blows the trunk security if you can get in by taking out a couple of screws from the outside of the car ??!!
Old 03-22-2010, 10:31 AM
Gman58
Gman58's Avatar
Default Locked out
Why don't you drive it over to a locksmith and have him check it out. That would be a lot better then punching out your trunk emblem. Greg
Old 03-22-2010, 10:44 AM
C-1 Generation 2
I'll probably have everyone with a 61/62 checking to see if it'll work.Mines in body shop now so I can't check to be sure you can get in that way.
Old 03-22-2010, 01:02 PM
arw57
arw57's Avatar
Default lock
You cannot get into the truck thru the emblem on a 56 vette. Just 3 little 1/8 holes and tabs the hold the emblem on. Call a Locksmith!
To C1 Trunk Lock
Quick Reply: C1 Trunk Lock
