pilot bushing help
CJS is correct. Have run into this problem myself and used a Dorman conversion bearing for use with powergide crankshafts and manual trannys. The conversion bearing are approx .029 smaller.
I wrote the P/n down in my parts book but I believe it has been superceded.
Anyway a google search came up with Dorman P/N 690034 .593x1.065
The standard being .593x1.095.
There is also a bushing for turboglide transmissions which uses a 1.073 bushing and is Dorman P/n 690035.
Taking a measurement is your best bet to obtain the right bushing.
Lol
Bob
Lol
Bob
Lol
Bob
Lol
Bob
What an 18 yr old will do, I did.
Cruise-In III Veteran
1Redctoo,
Straight from Corvette Enthusiast's April issue...an article on clutch, pressure plate, bell housing AND pilot bushings by John Hinckley (JOHNZ).
"You want a bushing made from 100-percent Oilite bronze, which won't attract a magnet. GM #3752487, #10125896, NAPA #BK-6151161, and Federal-Mogul #PB-656-HD are known to be made from the correct material."
Jim
In God We Trust!
Jim
In God We Trust!
bushing
Guess I should have added what tranny I have . It's the original muncie 4 speed . Numbers look right for the car .
The bushing is a Napa bk-6151161 .
Now I'm wondering if maybe the crank was changed somewhere along the line . Maybe a PG crank was used during this rebuild by mistake !
I'll try to remove the bushing soon using one or two of the methods suggested above . Then it's off to my machinist to see what can be done .
Received 1,844 Likes
Going from memory, the oillite brass pilot bushing should have a 0.002 to 0.003 inch interference with the hole in the crank flange. That is, the oillite bushing is 0.002 to 0.003 inches larger in diameter than the flange hole. I also believe that the flange side of this bushing has a small taper or bevel edge to help in assembly.
If needed, you can machine down the outer diameter of the oillite bushing to get the correct fit. DO NOT machine or alter the inside diameter or it will screw up (close off) the oil pores in the bushing which is not good.
Also make sure the new bushing slides easily on your trans input shaft nose before you install it. Tools are available to install, but most folks use an old trans input shaft or make their own. I made one from an oak dowel(s). One slightly larger than the bushing OD to pound on and a small second one epoxied or nailed in to just fit the ID and keep things centered.
Larry
Larry
You should take it out and check it anyway. Use the old mechanics trick of packing the hole with heavy grease (wheel bearing) and using an old input shaft or anything of same diameter, start tapping it into the hole, put in more grease as you need it, and amazingly the grease pushes out the bushing. Then get the right one!
Just did this and it worked like a charm getting my pilot bearing out.
High five to Kerrmugeon.
The cool thing about Kerrmugeon's grease trick is that it did not ruin the bearing.
I was installing a new one and got it started a little crooked.
I didn't want to clamp down on it with channel locks and pry it out.
