TPI in C1 anyone running this?
Several on this forum. I know of a 60 here locally, and there will be one (90 L-98) in my 62 in a month or so.
No hood clearance problems at all that I've heard of.
Russ
Russ
Thanks just wanted to recheck and then recheck!! I am talking w/ the tec guys from TPIS and they wanted to make sure. They are helping me do the build so I can build it right.
Russ
I have a TPI from a 90/91 car with everything harness, ECM fuel pump filter injectors etc, that I may put on my 1962 327 block - all I need to do is buy heads and a cam --- HOWEVER I may sell that set up for a few hundred $$ and just add that to a new mini ram TPIS system on the same 327. I have the BW `T10 4 speed by may go to a 700R4
Yes you can get a 700R4 in the trans tunnel with a little modification to the right side. Just a little fiberglass area there the 1-2 piston is on trans. You might not have to if you don't want, but it will almost touch in this area if you don't. I have a 700R4 with 355 TPI ,90 Corvette ECM running in 61 vette.
