Correct Tach Drive for 1958?
Hello - I have two tach drives and I'd like to know if either are correct. One has stamp "L 10" and the other has "L 5" with a circle around the "L".
Anyone have any idea's on if these are original, or what year?
Received 3,773 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Tom Parsons
Tach Drive units....the assembly that bolts on to the back of the generator. Also I have another question. I have a pulley that is 3 3/8" in diameter (outer edge to outer edge or the pulley). I believe it should be 3 5/8"...can anyone verify?
Received 1,859 Likes
The tach-drive generator gearboxes were all the same - the L5 and L10 markings are mold numbers. Base engines used a 3-3/8" dia. pulley with a 3/8" groove width, optional engines used a 3-5/8" dia. pulley with a 1/2" groove width.
Tom Parsons
I wonder why all the corvette dealers sell 3 5/8"...nobody mentions the 3 3/8". Thanks!
Questions for John Z
My 60 generator has had a 3" dia pulley with 3/8" width for many years. This might explain the long standing overstating of rpm, even after recent tach rebuild? Presently about 11% high, used to be even more.
Being an engineer, all I can say is that having different pulley sizes is going to change your RPM readings...so its confusing to me. Did they have different gearing systems in the tach for the different pulleys??
John (above) apparently is correct...as someone else told me they looked it up and base engines had the 3 3/8" pulley. Strange why they would change the pulley for different engines.
BUT, the speedo/tach CAN be calibrated. The indicator needle is moved to a higher position as the tach spins faster. This is caused by a spinning magnet inside the head. The faster the magnet spins, the more the needle is energized (if that is a good description). The amount of increase or rise of the needle can be adjusted by a knowledgeable speedo technician. It is a fairly easy adjustment (provided you know what the heck you are doing) and you need a speedo calibrating machine which spins the speedo/tach head while the adjustment is made (I've watched the guy at the local speedo shop while he did this for me). I have what appears to be a matching tach and speedo in my 51 Chevy. I made the tach from another 51 Chevy speedometer and had the speedo shop guy recalibrate it to indicate rpm instead of mph. After I saw how he did the adjustment, I could have done the adjustment myself, but I don't have the machine to indicate the rpm's that are desired. My home made ("factory") 51 tach is driven by a Vette tach drive distributor, just as it's done in a Vette.
Tom Parsons
Thanks Tom....this is what I love about this forum...the things you learn!
Thanks!
Thanks!
The 4"-diameter pulley was used on solid-lifter fuelies with distributor-driven tachometers, to reduce generator rpm under "sustained high-rpm operation".
Thank John....your answer, basically answered my question. As an engineer I was scratching my head on how could they have different pulley sizes and yet the same tach (rpm gauge). WOW...I can sleep tonight!
Tom Parsons
Thanks for the education!
The gearbox output rpm was the same with either pulley - the 3-5/8" pulley with the 1/2"-wide groove was a "deep-groove" pulley (to keep the belt from coming off), and the belt rode deeper in the groove than it did with the 3-3/8" pulley which had a narrower (3/8") groove.
So, it would appear that the tach drive generators run exactly double engine speed, then that is reduced 50% to engine speed so that tach cable turns engine speed. Distributor drive cables run half engine speed. The tachs are all essentially the same but are calibrated to either same cable rpm for gen drive or double cable rpm for tach drive. That was good to know!
