Head casting #'s
are you sure the first # is not a 3??
..68......327.........."Right angle" casting identifier, 64cc chambers, good HP head,
used in trucks, no accessory holes
3947041....69-70...302/350......"Right angle" casting identifier, 64cc chamber, accessory holes, good HP head
3947041X...69-70...302/350......"Right angle" casting identifier, 64cc chamber, 165cc intake port, accessory holes, good HP head
3951598....70......400..........76cc chambers
3964286............350
3965742.
3965742.
3965742.
3965742.
Received 1,857 Likes
casting numbers
a good reference book I have is 1955-82 Corvette by the numbers by Alan L. Colvin
it shows Head#3947041 on page 153 apply to 1969 350 cu. 300 HP, unverified on the 350 HP, and 1970 350 cu 350 & 370 HP.
In the notes section it states the head is identical with #3782461 (a 327 head used in 1965 and 1966) except for a redisgned combustion chamber, the addition of a temperature sending unit boss and 3 accessory bolt holes added to the end of each head. This head was interchanged on some models with #3927186 and 3927187.
hope this helps
hope this helps
hope this helps
hope this helps
hope this helps
hope this helps
