Rear body mount cushions on 63
The body mount kit for my 63' came with two rectangle rubber cushions. I can't remember where these went. Help?
Bob
Bob
I'm thinking you are talking about the two rear pan supports in front of the diff on 63/64's. But I'm also thinking my originals were round when I removed them but I don't remember for certain and couldn't find a decent picture.
I recall they go on top of the rear kick ups in between the frame and body in line approximately of the centerline of the rear wheels. I think you need to glue them in place so they don't shift around.
Scott
Scott
They are not the round pan support cushions. These are about 6" long x 1" wide x 1/2" thick and are ribbed. I believe they are a 63' only item.
Does anyone have a picture or diagram of where they go?
Thanks,
Bob
Thanks,
Bob
Location: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
They go on the rear cross piece right behind the rear end between the body and the frame about 24" apart. Yeah, tape or glue them. When you pull all the body mounts down they get tight.
I forgot all about those. I've seen them before but I don't recall pulling them out on my convertible and the body was never off. Wonder if they can fall out. Mine was a late July car so maybe they didn't include them then? Either way, thanks.
When I disassembled my car those pads were there on the frame as shown in C2ray's photo. They were glued on and when I reassembled the car I used weather stripping cement to put them back in place.
Rich
Rich
Could you tell us an approximate VIN number for your car. Sometime like 123XXX would be fine. I'm curious if these might be something found only on early 63 coupes. The only purpose I can think of is a floor support for the "Jump Seat" that never materialized as a 63 production feature.
tc
My car is an approximate 27 Nov 62 production and the serial number is under 4000.
Rich
Rich
This is almost the same shot of the same chassis I posted above. Vin 19761, July 18th approx. Note that if they were ever there, you would probably see some type of mark on the frame where they were. Nothing, nada, zip. They were also not stuck to the underside of the body.
Mine is an April 23 car. I'll probably put them on anyways. Can't see it hurting anything. These 63's can use all the cushioning they can get. I'm not going to glue them though in case I do need to slide them out if they interfer or hold the body up too high.
Bob
Bob
Here is the only shot I have of the cushion in the original position after removal of the body.
