Help identify an engine.Is it correct for my 1964?
Old 01-11-2010, 08:19 PM
TheSaint
Support Corvetteforum!
TheSaint's Avatar
Default Help identify an engine.Is it correct for my 1964?
Looking for a correct engine for my 1964.My car was manufactured in december 1963(D5)
I came over this engine and need some help to decode it
Here is the info the seller sent me:
The only number I can find for a date stamp is "J232" That number is located on the top right rear of the block, behind the right head. The other number on the back left side of the block, that is the GM number is 3782870.
The number under the passenger side head is FA36985.
The small number is L145112. Let me know if this helps. Also, the GM number I sent over shows an earlier year manufactured
327, I believe it was 1962 - 1965.
Old 01-11-2010, 08:23 PM
MiguelsC2
MiguelsC2's Avatar
St. Jude Donor '10-'12-'13
CORRECTED
I think that is an October 62 block which puts it a year too early for your 64. "I thought yours was a 63 when I commented". I am told NCRS gives you a 4 month window. Mine is a k62 with a March build. Non original block. I am sure the real experts will chime in soon to correct or confirm.
Old 01-11-2010, 08:29 PM
jkuzzy
jkuzzy's Avatar
October of 62 would be for a 63 or am I missing something? I have looked for a decent price on a late 63 block forever since mine was born on January 20th of 64. I finally rebuilt what I had.
Old 01-11-2010, 08:52 PM
TheSaint
TheSaint's Avatar
It got to right for my car wich is a 1964 model. Assembled D5 wich is December 1963 if i am not wrong.
Old 01-11-2010, 09:11 PM
dkleather
dkleather's Avatar
2016 C2 of the Year Finalist
The date code J232 indicates October 23, 1962 which is too early for your December 5, 1963 car if you're trying to stay within the four month limits for a "correct" engine. Even four months, I'm told, is stretching the limits. Six weeks or less would be the ideal. Couldn't find the head numbers in anything relating to Corvette but I could be wrong on that since my references are limited. Dave
Old 01-11-2010, 09:36 PM
TheSaint
TheSaint's Avatar
I was hoping that it was the right one or my car.
Old 01-11-2010, 10:51 PM
MiguelsC2
MiguelsC2's Avatar
Keep looking it's out there.
Old 01-12-2010, 12:08 PM
JohnZ
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
D5 is December 5th if it's a St. Louis body, or April 5th if it's an A.O. Smith body. Is there a letter ("A" or "S") in front of the "Body" number on the trim tag?
You need a 3782870 block (from Flint, not Tonawanda) cast not more than six months prior to your car's final assembly date. A Flint block will have a single digit for the year in the casting date, and a Tonawanda block will have two digits for the year. A Flint block will also have a square-head 1/8" NPT plug just above the timing cover at about 11 o'clock - Tonawanda blocks don't have that plug.
Old 01-12-2010, 01:44 PM
TheSaint
TheSaint's Avatar
Yes there is an S right that inicates St. Louis.
But i also saw some pictures where the suffix is and that is on the engine close to the bell house.Am i right?Serial number and suffix?
My car if i am right should have a RR suffix. SHP with AC.
Old 01-12-2010, 02:01 PM
TheSaint
TheSaint's Avatar
Just got an offer from somebody that have engines
Here is the number of a block they have:bare block J-14-3 tested
Old 01-12-2010, 02:39 PM
stingrayl76
stingrayl76's Avatar
The block casting number is close to the bell housing, and the Serial number and the suffix are stamped on top of the block surface in front of the right cylinder head.
This link should help you out===> CLICK
This is a great site with a multitude of infomation thanks to barryk.===>CLICK for Vettetech
If your engine is a 365HP, manual trans, A/C without T/I, then the suffix should be RR. If it has T/I, it should be a RU.
Old 01-12-2010, 02:48 PM
TheSaint
TheSaint's Avatar
Thank you stingrayl76
Great
To Help identify an engine.Is it correct for my 1964?
Quick Reply: Help identify an engine.Is it correct for my 1964?
