54 old registration pic
Moderator
When I bought this car the seller gave me old registrations from the guy he bought it from. While cleaning the frame I came across an extra set of #'s on the left upper frame member fwd of the firewall. I thought it was strange because the # started with a DRF (my initials). In looking the registration over I spotted in the upper left corner these exact numbers listed as 'vehicle identification'. Too wierd! The correct vin # is on the left upper frame fwd of the left wheel hump and matches the vin tag.....it is S54004545. Any thoughts? Also I could use any advice you have on trying to locate this guy. I've kinda hit a dead end. Oh BTW, I still have the black and yellow Calif. license plate listed on the registration.
http://i33.photobucket.com/albums/d6...istration5.jpg
http://i33.photobucket.com/albums/d6...istration1.jpg
Moderator
I suppose, dunno really. The registration/title I got when I bought it has the correct vin # S54004545 on the title and these numbers match the frame stamp and vin tag. Maybe Calif. needed to put their own ID # on it also for some reason. Strange that the Calif DMV made the owner stamp their # on the frame along with the original vin.
Received 6,547 Likes
C2 of Year Finalist (track prepared) 2019
The next question is why did Kalifornia think it necessary to issue a new VIN?
Jim
Moderator
Dunno Jim, maybe like yours it's an original Kalifornia car?
Russ
Engine Number???
Does your car have the original motor....and F54YG stamping? California used to title cars by the motor number, not the VIN number. If your car was missing the original block, depending on when this title was issued, then California may have issued a "replacement" VIN number due to having a non-original block. A friend of mine restored a 1954 here in Kentucky that came from California, a black plate car last titled in the late 1960's or early 1970's and it had the original block and the car's title was the motor number, blah-blah-blah-F54YG. It took him MONTHS to get Kentucky title under the VIN number based on the tag on the door. This might help you.....maybe???
Moderator
You may be on to something with the VIN being from a replacement engine...it appears to me that on your registration it says it had an 8 cylinder engine in it at that time possibly.
It also appears that the registerer has passed away, he was born in Souix City, Iowa in 1928. His name is Hollis Burton Bouvia ...Bouvia was his last name. Here is a link to contact his wife (if shes still alive)
http://community.ancestry.com/profil...?cba=kalla1939
Hope that helps...
Hope that helps...
Moderator
Hope that helps...
Hope that helps...
54 Corvette
My DAD is the person that you are taking about, my name is Hollis Bouvia all so.If you still own it maybe I can answer your questions. My phone number is (360)228-8077,I live in Shelton,WA 98584.O was in highschool when he was putting it together.He bought a parts 54 Corvette with the 6cyl in it.Please call me I would like to you. If you have a hard time to get me on the phone,I live in a hard place to get phone calls Just text me and I'll call you Thank you.
csherman (06-13-2022)
