Is anyone running BF Goodrich Radial TAs
Seems that all the posts have been positive for this tire. I bought my car with 70's era BFG TA's and replaced them with new BFG TA's. They look great on my chromed wide Rallyes.
BUT, the car seemed a little squirrely to me at high speeds, and I never thought it was the tires until mechron showed me just how much they move laterally upon side pressure to the fenders. They aren't as stiff as, say, Goodyear Eagles, which I heard aren't available anymore.
So I'm learning how to do proper burnouts and will replace with Goodyear or high end Michelins (I had the Pilots on my MBZ 560 SEC). I really liked the BFG's but I think I want a performance tire next.
now i buy NASCAR good year eagles, they are unused nascar tires off Ebay, and are cheap and unused tires.
more info later,l i'm tired,,,
Check out Firestone Firehawk Indy 500
I run a larger rear tire on my 65, so after mid to low satisfaction running through two sets of BFG Radial T/A the only alternative I could find to match the tires in both sizes were Firestone Firehawk Indy 500.
Bought 'em through TireRack a few years ago and so glad I switched. IMHO the Firehawks are a far superior tire. Better ride, cornering, wet traction, quieter and better looking too.
PaulUptime, any photos of the car with those Firestones? The OP may be just wanting the stock size tires, which probably can be found in many brands. My larger tires in the rear will be 295 or 305/15/10, so I am limited. BFG didn't have those sizes, so I compromised with 275 and I regret it.
The tires are 215/70/15 front and 235/70/15 rears.
You can see them on my '65 in my pic gallery, and the supersize closeup image at TireRack.
Here's my preferred view of them (in motion)
I've got 21-yo T/As myself (it's long past time to replace them), so I've been shopping too. Check out the Tire Rack ratings for the old muscle-car sized tires:
BF Goodrich TA Radial, Spirited Driving Style, 216 votes, Average Overall Rating = 7.46.
Compare that to the Firestone Firehawk Indy 500, Spirited Driving Style, 427 votes, Average Overall Rating = 8.49.
Read through some of the comments; hardly a negative one for the Firestone tires. I've been very happy with each of 4 tire purchases based on Tire Rack survey results. I'll probably be going with the Indy 500's this time.
Received 4,562 Likes
2016 C2 of Year
2015 C3 of Year Finalist
I had BFG Radial T/As on my '73 and later on my '58 Corvette. Back then, I loved them. I really liked them at the time, as they were easily balanced, relatively light, vibration free, well behaved, etc. A good non-steel belted everyday driving tire as I recall. I experienced no fender rub issues.
Please correct me if I'm wrong, but isn't there a fender rub problem with a 215/70 R15 tire size on a C2? Isn't the Coker size 205/75 R15 nylon radial (or possibly a 205/75 R15 all-season steel-belted specialty tire modified by Diamond Back) about as large as can be used safely under a non-flared C2 fender?
I had to fix all four fenders on my '65, due to damage I believe resulted from 215/70 R15 BFGs and Goodyears over the years. According to the previous owner, the damage occurred over time when big bumps/dips were hit. Can't small bumps potentially can damage the front fenders with the wheels turned all the way. The 8" tread width is huge compared to the 4.67" tread of the stock tire. Anybody have experience with this? Is this all in my head? Would really appreciate some clarification on this.
Rub issues
Since these cars all sit differently with years of unique experience and mods behind them, fit and rub issues will vary.
My car arrived to me 10 years ago pretty much as you see it in my pictures. Rear fender flares, a 454 big block and composite rear leaf. It was running a set of older BFG Radial T/A's and there were no sign the tires were scrubbing the fenders anywhere.
Not long after getting the car, I experienced total tread separation of the drivers side front tire at speed on the highway. The fender and rocker area sustained some damage and in an instant I was driving on bare belts but the tire stayed inflated. I blamed age/dry rot and replaced them with another set of the same size/type BFG's. A full alignment was done to ensure they were rolling without additional stresses.
That set lasted a few years but I would never consider the Radial T/A's offered any performance or ride benefits. Since then, I've changed out my front springs when the car went back to small block, and I switched my Muncie to a Keisler/Tremec 5spd. Still no rub issues.
Switching to the Firehawks immediately improved the way the car tracks, rides and I think looks better too. We'll see even more benefits when this week when I swap in a new Borgeson steering box, all new shocks and complete bushing overhaul with Prothane components.
Everyone's experience will differ, but my next set will likely be another round of the same Firehawks.
#33
2016 C2 of Year
#35
I have used T/A's for about 25 years with excellent street results on everything from my C2 to my Suburban to my daughter's old BMW. I am getting 60-70,00 miles per tire on the heavy Suburban. No flats or other problems as experienced with Firestone and Goodyear, and the BFG dealers seem much nicer in my experience.
Some complain about "squirreliness". I have learned through experimentation that these tires need more air pressure for best handling and mileage, at least 36 pounds all around for the C2 on the street and about 40 front and 32 rear for slaloms. The Suburban does best with 39 pounds all around.
BTW the T/A's Greenwood used on his race 'Vettes were quite different from today's, with RAYON belt construction. That said, IMO almost any good S or up-rated modern street tire is equal or better than the race tires of 30 years ago.
