327 365HP oil
Old 07-20-2009, 07:48 PM
1965 L76
Navigator
1965 L76's Avatar
Default 327 365HP oil
I have a 1965 327 365hp vette and I was wanting to know what type of oil the use in that old engine or if it makes any differance what I use.
Old 07-20-2009, 07:57 PM
LT1driver
LT1driver's Avatar
something with high zddp, many use shell retello multiweight diesel oil, duke over at ncrs and formally here highly recommends it and used for years with no issues.....my choice as well
Old 07-20-2009, 08:04 PM
Engine Doctor
Engine Doctor's Avatar
It all depends on your oil clearances!
For the most part, you need .001 clearance per journal diameter.
This will for sure vary with diff. applications. Ex: indurance / marine etc.
If you don't know your oil clearances....try 20/50wt and if you
are running a flat tappet cam make sure u have Hi Zinc Content
Old 07-20-2009, 08:30 PM
1snake
1snake's Avatar
Any oil with a CI-4 or CJ-4 API will be fine. Don't buy into all the "ZDDP additive BS". They are not needed and are a waste of money.
Jim
Old 07-20-2009, 09:49 PM
Engine Doctor
Old 07-20-2009, 10:43 PM
mn.roadking
mn.roadking's Avatar
I know of camshaft premature failure. Some engine experts and car mag articles blame it on low zinc oil. For the extra $10 a year, why not be safe? You can break the engine in with an oil like Brad Penn "Penn Grade" which is a high zinc content racing oil, then switch to synthetic.
Old 07-20-2009, 10:52 PM
1snake
1snake's Avatar
Don't believe everything read or hear. It is B.S. I have a better idea. Use the oil I recommended that has been proven to work by those that aren't trying to sell you something, and send me $10 a year so we'll both be happy.
Old 07-21-2009, 10:16 AM
Kensmith
Support Corvetteforum!
Kensmith's Avatar
Shell Rotella T 15-40wt. You can find it at many parts stores in gallon containers
Old 07-22-2009, 08:46 PM
mn.roadking
In my experience, it doesn't pay to be cheap. The engine builder who gave me the advise has been doing this for 40 years and builds most of the engines used by stock car racers in ND. There is a reason zinc was in the formula used in oils and if the EPA mandates a change you can be assured there is a downside to the change.
Old 07-22-2009, 09:05 PM
knight37128
knight37128's Avatar
I lost a flat tappet cam.
I was using Shell CI-4.
No worries, nothing but a roller cam from now on.
Old 07-22-2009, 11:32 PM
Engine Doctor
I agree
Old 07-23-2009, 12:16 AM
1snake
1snake's Avatar
It's threads like this that caused Duke to say "F--K It" and quit posting here. Too many people that don't know **** posting B.S. If you want the truth about oil, read one of the many articles he has written for several magazines or his many posts on the subject on the NCRS and other forums. His articles are based on fact and scientific evidence, not hear-say, rumors or what some engine builder named Bubba tells his customers.
Jim
Old 07-23-2009, 12:41 AM
Engine Doctor
Jim
But who are you referring to
Everyone is entitled to an opinion, be it text book or hands on
Thought this was a friendly place
Old 07-23-2009, 07:29 AM
obx2323
obx2323's Avatar
Why worry, Shell Rotella 15-40. Got zinc, good price and good oil. I run the pi$$ out of my built 350 and it's very happy when I take it out for stroll.
Old 07-23-2009, 09:16 AM
1snake
1snake's Avatar
Duke Williams. Most here know who he is.
Old 07-23-2009, 10:12 AM
Kensmith
Kensmith's Avatar
It's kind of funny when someone asks for help or has a general question some forum members will object to other members ideas. Everyone has their own opinion weather it's from reading books, magazines, or just from conversation. There is so much information that it gets confusing at times. Then we tend to defend what we have used in the past because it works for us. Not sure in this post there is a 100% correct answer to best oil. There are so many types and additives so how do you decide? You can spend days searching the Internet reading all the great stuff about tests and scientific findings. They are probably all good for most motors. If you change the oil before it gets too dirty or starts to break down, you will probably be fine. If you use oil that the engine builders and racers use, you will probably pay a little more but with a solid lifter motor, might be worth it. I choose Shell Rotella T 15-40wt because of what I read and I had a solid lifter motor. Then I ordered a 383 stroker roller cam motor and the builder told me to use Shell Rotella T 15-40wt without knowing I already use it. All I know is a bunch of forum members with high winding motors use it, John Z likes it, cost is not a factor nor is locating it. So I use it.
Old 07-23-2009, 10:40 AM
Jims66
Jims66's Avatar
Since we're all kicking in......, I've used Mobil-1 15W-50 (currently with 1200ppm of ZDDP) since we put my L79 together back in 1989-90.
To 327 365HP oil
Old 07-23-2009, 10:51 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
If someone decides not to post its their decision, noone made them do it. Some just dont like others disagreeing with them or possibly being corrected.
Old 07-23-2009, 11:16 AM
GCD1962
GCD1962's Avatar
Jim
Maybe true, but he couldn't take an ounce of criticism, and wouldn't agree with any one that had a different (and correct) point of view.
Old 07-23-2009, 11:42 AM
abe g
abe g's Avatar
Default type of oil in older cars
I am the original owner of a 63 swc with 100,000 original miles. Engine uses NO oil (other than small pan leak from original gasket). I have been using good grade of ANY oil for the last 48 years without any undue engine wear. oIL PRESSURE SHOWS FINE. In my opinion this question is overated! Just my 2 cents, regards,, Abe G
Quick Reply: 327 365HP oil
