Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-12-2009, 01:56 PM   #1
chub
CF Senior Member
chub's Avatar
Default spark plug wiring diagram
Does anyone have a diagram of the plug wiring diagram for a 66 327 350hp? I have a service manual but apparently I am blinder than a bat cause I can't find it.
Chub
chub is offline   Reply With Quote
Old 07-12-2009, 02:02 PM   #2
62Jeff
Support Corvetteforum!
62Jeff's Avatar
What specifically are you in need of?
The clocking of the wires on the cap, the routing of the wires down to the oil pan and back up through the motor mounts to plugs 1, 2, 3, 4, the order in which the 4 wires are routed through the loom on each side?
Etc. We can help, once we know more about what you need
62Jeff is offline   Reply With Quote
Old 07-12-2009, 02:08 PM   #3
ml1955
CF Senior Member
ml1955's Avatar
http://www.classiccarauto.com/impala...istributor.png
Try this diagram, #1 plug on cap is after the window to adjust pints if I remember correctly... My '55 cap does not have the modern technology of those later caps
ml1955 is offline   Reply With Quote
Old 07-12-2009, 02:08 PM   #4
chub
CF Senior Member
chub's Avatar
jeff, I have a dead miss. The plugs are new so I thought that I could have a plug wire connected to the wrong plug in the firing order. I am going to trace the wires but I was looking for a pic of the wires on the distributor for firing order.
Chub
Old 07-12-2009, 02:12 PM   #5
62Jeff
62Jeff's Avatar
Quote:
Chub
Firing order is 1 8 4 3 6 5 7 2. Typically the #1 wire is between the points window and the vacuum advance.
Edit: Looks like ml1955 has it covered.
Old 07-12-2009, 02:12 PM   #6
chub
CF Senior Member
chub's Avatar
thanks ml1955.
chub
Old 07-12-2009, 02:14 PM   #7
chub
CF Senior Member
chub's Avatar
Thanks to both of you.
Chub
Old 07-12-2009, 03:05 PM   #8
JohnZ
CF Senior Member
Here's a photo...
JohnZ is offline   Reply With Quote
Old 07-12-2009, 04:14 PM   #9
BarryK
CF Senior Member
BarryK's Avatar
Click the image to open in full size.
BarryK is offline   Reply With Quote
Old 07-12-2009, 05:24 PM   #10
magicv8
9 Hot Rod Power Tours
magicv8's Avatar
There are links to Corvette wiring diagrams in the help
section near the bottom of this web page
( http://home.mchsi.com/~magicv8/index.html )
that show the wiring sequence and routing.
magicv8 is offline   Reply With Quote
Old 07-12-2009, 06:16 PM   #11
chub
CF Senior Member
chub's Avatar
Thanks John z, barry and magic it helps a lot. Sorry it took so long to respond but I have been under the car.
Chub
Old 07-12-2009, 06:20 PM   #12
Black_Magic
CF Senior Member
CI 2-3-4-5-6-7-9-10-11 Vet
CI 4-5-7-9-10-11 Car Show Winner
Black_Magic's Avatar
And another
George
Black_Magic is offline   Reply With Quote
Old 07-12-2009, 06:24 PM   #13
chub
CF Senior Member
chub's Avatar
thanks black magic
Reload this Page spark plug wiring diagram
Tags
1966, 327, 84, c3, c5, corvette, diagram, distributor, firing, order, plug, routing, spark, wire, wiring
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
