1961 Starter Solenoid
Old 06-12-2009, 12:50 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
Default 1961 Starter Solenoid
I have a date code/numerically correct starter housing on my C1. However, the solenoid has the number: 1119919 which (from my research) is only applicable to 1957 vettes. Does anyone know the correct number for 1961 ?
Its not keeping me up nights but I'd like to know if its worth rebuilding the correct solenoid or just get a vendor replacement.
Frank
Old 06-12-2009, 01:37 PM
chris ritchie
chris ritchie's Avatar
Go see EBay item
400027467499
He says that's a 1961 solenoid and gives some explanation.
I don't know anything about this seller or this part.
Old 06-12-2009, 01:47 PM
Frankie the Fink
Army
Originally Posted by chris ritchie
Go see EBay item
400027467499
Thanks for that link...on a second inspection my last number is a '0' and not a '9' so according to this fella my solenoid is original. Interestingly my number is stamped longwise on the part and not crossways as shown in his ad...maybe that doesn't matter.
Old 06-12-2009, 02:27 PM
1955 copper
1955 copper's Avatar
2015 C1 of Year
While your talking starter Solenoids if you ever find a 55 Corvette only #1119767 solenoid like the pic. By it , it's the rarest one ever made 12V , it's the only one NOT having a "R" post for any accessories
Old 06-12-2009, 02:33 PM
Frankie the Fink
Army
I'll sure keep an eye out Roy...my chance of finding one of these is right up there with my odds of getting a date with Angelina Jolie...
Old 06-12-2009, 02:53 PM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
The '55-'56 pass car solenoid does not have an R post either. Corvette different part #?
Old 06-12-2009, 03:54 PM
1955 copper
2015 C1 of Year
But it has two post for accessories ( power window seats AC) right?
Old 06-12-2009, 05:06 PM
MikeM
MikeM's Avatar
The '55-'56 pass car solenoid terminals look like the picture that's posted. The R post, or the extra outboard terminal that feeds the coil with the key in "start" position came on board in '57 in pass cars.
I don't know anything about the accessory wiring you're speaking of.
Old 06-12-2009, 05:26 PM
stellar
stellar's Avatar
where is Angelina? I have a couple with the same cap (no R post) but different # I only have one with 1119767 and no R post. It is on a starter# 1107627 4J29. And I don't have a car to put it on. Do you think Angelina would like golf or scuba better?
Old 06-12-2009, 05:54 PM
stellar
stellar's Avatar
I have an 1107889 1L4 with the 1119910 sol and I have an 1107664 1L20 with 1114362 sol both of which I believe are original. These may be to late to be 1961 and may be 1962, I don't know, but it tells me the sol you have may be correct for the 1961 1119910. I have not seen a number stamped longwise, but that doesn't mean it isn't original. I looked at the ebay and it seems as if Delco may have been using multiple #ed sol at the time. Also the original solenoids were painted black.
Old 06-13-2009, 06:08 AM
mike coletta
mike coletta's Avatar
Received 1,067 Likes on 513 Posts
Hey Frank,
The solenoid part number and date code are NOT judged. The starter case should be 1107889 or possibly 1107664. The correct number for the solenoid is 1119919, if you are so inclined. I would just put the aftermarket on it, and go for that date with Angelina!!!! Whooo-hoooo!!!!! Mike
Old 06-13-2009, 06:12 AM
mike coletta
BTW, the solenoid number for 62 is 111910. All of this information is right out of the NCRS judging manual for 61/62 cars. Mike
Old 06-13-2009, 06:16 AM
mike coletta
I left a 9 out of the last post. 62=1119910. The one that you have 1119919 is 57 only.
Old 06-13-2009, 11:55 AM
Frankie the Fink
Army
Thanks Mike -- the correctly numbered/date code correct starter is at Steve's Electric in Clermont or a rebuild....if they can save the solenoid fine, if not a replacement is fine with me!
To 1961 Starter Solenoid
Quick Reply: 1961 Starter Solenoid
