borgeson power steering conversion
Cruising
has anyone installed the borgeson power steering. it looks like a direct bolt in unlike the jeep conversion, but does it work as well. car is a 66 sb. i did find thread for later cars but anyone do mid year car
I realize it does not include a power steering pump or mounting brackets.
After viewing the website for Borgeson power steering conversion for a midyear corvette 63 - 66 it appears that you are using a remanufactured box that bolts directly onto the frame in lieu of using spacers like you need with a Jeep box.
Did I read correctly that you also need a hose kit?
Rich
Borgeson: The Summit photo shows a steering shaft as part of the kit. Do you provide that for pre-67 Corvettes, so we don't have to cut the original shaft? Also, any issues with header clearance?
Harry
Harry
Harry
