Part Identification help....
Old 06-04-2009, 06:23 PM
RickSnow
RickSnow's Avatar
Default Part Identification help....
I found an AC Delco box in the basement with a never used part in it. Can anyone help me to identify what it is.
Part number is 1114532
Gr.2.100
1#D989
3263E9
SWITCH.
Thanks for the help.
Rick.
Old 06-04-2009, 07:37 PM
Gman58
Support Corvetteforum!
Gman58's Avatar
Default Magnetic Switch
Just Google the part number and you'll find that it is a magnetic switch. For what purpose I don't know. Oh yeah about 17 to 20 dollars. Greg
Old 06-04-2009, 07:40 PM
stellar
stellar's Avatar
1114532 solenoid 12 volt 3 terminal intermittent duty. Most likley for early 12volt truck forklift or other equipment starter. Keep it. It can be used for many things. Replacement cost for an OE delco is probably close to $50.00 Mark
Old 06-04-2009, 07:49 PM
stellar
stellar's Avatar
Aftermarket part around $30.00 It fits on delco starters 1107803 806 808 809 814, and probably others. Can be used to replace a ford fender mounted solenoid. hydraulic pump motors and much more. It is a pretty universal part. 2 big posts one to battery other to motor you want to energize. 1 small post pos power to engage switch like the s post on your auto solenoid. Case must be grounded. Mark
To Part Identification help....
Quick Reply: Part Identification help....
