Rubber seal convertible top 1966
Rubber seal Hard Top convertible top 1966, purchased a new seal and will be installing tomorrow, any pointers, help?
Thanks!
Thanks!
Which seal? If the front bead, you have to slide it under the clips. If the clips are bad, you have to remove the front stainless strip to install new clips. The others are rather straight forward. Screws or glue.
