Motor has started backwards a couple times
Old 06-03-2009, 05:52 PM
AZDoug
AZDoug's Avatar
Received 1,478 Likes on 905 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Default Motor has started backwards a couple times
It runs backwards, too, not very well, though.
Retard the static timing a few degrees maybe? Set at 10 BTDC now.
Easy enough to set 200 RPM timing to say 4 degrees BTDC or even zero, and still have it at 10 degrees static at 750 RPM idle with the EFI
It has only happened twice,and when hot.
Rather annoying as it pumps the intake and air cleaner full of exhaust,and then of course it wants to flood on restart with no oxygen in the air to burn the gas.
Doug
Old 06-03-2009, 06:11 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
usually that happens because of 'kickback' from too slow a cranking speed, too much compression, too much timing; or any/all of the above...
with the right camshaft, an engine will run in either direction
Bill
Old 06-03-2009, 08:02 PM
midyearvette
Support Corvetteforum!
midyearvette's Avatar
Bill
....although it wont last very long unless you turn the pistons around to offset the pins for counter rotation and usually have to change the firing order too....
Old 06-03-2009, 08:22 PM
Bill Irwin
Bill Irwin's Avatar
I never knew that could happen. Bill.
Old 06-03-2009, 08:33 PM
Trophy Blue
Trophy Blue's Avatar
Happens in Nascar races sometimes. The aftermath is not pretty.
Old 06-03-2009, 08:36 PM
rongold
rongold's Avatar
Location: Putnam Valley, New York. Amateur Radio Operator K2NS
Default Running backwards
Just remember, there is NO OIL PRESSURE if the pump is spinning backwards--in fact, the pump is trying to evacuate any oil that is in all of the passageways and the filter.
RON
Old 06-03-2009, 08:42 PM
NVaVettes
NVaVettes's Avatar
Hummmmmm......interesting!
My GMPP 454HO will very occasionally try to do something like this
when I go to start it after its been fully warmed up and then sits for
30-60 minutes. It cranks a little slow, won't start, and then when
I let off the key, it coughs and a big puff of white smoke comes up
thru the carbs.
Sounds like maybe backing off the timing a little bit might help?
Any other thoughts?
Thanks!
Don
Old 06-03-2009, 09:22 PM
midyearvette
thru the carbs.
Any other thoughts?
Thanks!
Don
too much initial timing......
Old 06-04-2009, 01:57 AM
AZDoug
AZDoug's Avatar
Yeah, i know about the oil pump.
It doesn't run very long, about long enuf to fire each cylinder maybe 2-3 times before I turn the key off and start over.
Doug
Old 06-04-2009, 06:07 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
Yup! Used to happen on my brother's motorcycle a few times...pretty exciting....
Old 06-04-2009, 06:26 AM
Matt Gruber
Matt Gruber's Avatar
that could be 1 of the reasons they make colder plugs
Old 06-04-2009, 01:14 PM
BlackbirdZ07
BlackbirdZ07's Avatar
Just put in it reverse to go forward; otherwise enjoy your four reverse gears!
Old 06-04-2009, 01:49 PM
midyearvette
reminds me of the guy i knew of back in the 60's who put a marine big block ford in his galaxie....all built up for a great price.....too bad it was reverse rotation....too bad he did'nt check that out before he installed it....after we changed out the cam, starter , pistons, and dizzy gear he had more coin in it than if he would have bought new from a ford dealer...it did run very strong i have to admit.......
Old 06-04-2009, 01:53 PM
GCD1962
GCD1962's Avatar
Happens to my chain saw every once in awhile. Runs real rough and chain goes in the wrong direction.
Old 06-04-2009, 03:21 PM
highschool67
highschool67's Avatar
I had a Mercury outboard back in the early 60's that had 2 starters. One started the 2 stroke going forward , one in reverse. This is how outboards motors ran both directions before transmissions were added.
Old 06-04-2009, 04:41 PM
Ironcross
Ironcross's Avatar
Default Your joking, right!
Whats that mean, they all start at the same temperature...dont they?...
How do you get a starter to crank backwards? that's impossible! The drive only starts or throws out in one direction...
Old 06-04-2009, 11:40 PM
SPLITRAY
SPLITRAY's Avatar
So, Just turn the engine end for end and swap the fan and the flywheel. Problem solved!
To Motor has started backwards a couple times
Old 06-05-2009, 09:19 AM
1Sweet66
1Sweet66's Avatar
Or try turning the key in the other direction!
Seriously, never heard of this before.
Old 06-05-2009, 10:03 AM
Chambered
Chambered's Avatar
I was just going to say to NEVER START THE CAR IN REVERSE!!!
Old 06-08-2009, 08:12 AM
stratplus
stratplus's Avatar
WOW, I use to tell people this and they would not believe me. This is the first time I have heard someone else talk about it. I still don't understand how it works.
I use to have a dirt bike with a 125cc Sachs engine with a 6 speed. If I was in 1st gear and went up a small incline and rolled the bike back wards while holding in the clutch then let the clutch out at the bottom of the incline while still rolling back wards the bike would go into a reverse mode. I could drive it and shift all the gears but only going in reverse. I had to stall the bike to get it to go forward again. No, I could not ride far in reverse without dumping it.
Quick Reply: Motor has started backwards a couple times
