67 A/C Control
67 A/C Control
Does the A/C ****, left side below the Clock, operate the Right side Kick Panel Vent? Also, anyone know the difference between Non-A/C Kick Panel Vent and an A/C version? (67 only). Thanks, Al W.
Al:
Yes it does operate the right-side vent door. Just pull it out to open door. Rotate for blower speed.
A schematic of all the AC controls/***** and detailed descriptions of what they do are on pages 1A24 to 1A26 in the 1967 Chevrolet Service Manual. Good info to have.
Larry
Larry
Received 1,857 Likes
With the factory A/C system, there was no right side vent like on a heater car. The vent door was replaced by the "adapter assembly", which controlled the source of air into the A/C evaporator; with the door closed, it took in outside air - with the door open, it took in inside cabin air (recirc mode for max cooling), and intermediate positions allowed a blend of inside and outside air to the evaporator core. A/C cars only had one outside air vent, on the driver's side. System operation is shown in great detail in the "Heating and Air Conditioning" section of the Chassis Service Manual.
Just the info. I needed, and I have the Manual. Thanks! Now, I installed the A/C in my car from a donor car years ago and am finally Tweaking it. The Cable we are talking about operates the Blower and should open the Vent but it is too short to reach the Non-A/C car. Could it be from an earlier year? Al W.
http://www.licorvette.com/pdfcatalogfiles/cat/12.pdf
Well once again the Forum Crew comes threw! Thanks to the answers which provided the places to look I am finally on the right track to finishing my OEM A/C install. A/C is pretty simple once you understand it! Thanks to all. Al W.
Ron is correct, it is a different cable that runs along bottom edge of glovebox to work its way over to the center control ****, hence it would be longer than the one for a non-AC car. It is also routed completely differently from a non-AC car.
Kirk
Kirk
Thanks for confirming this issue. What can you tell me about the Vent Cover on an A/C car VS a Non-A/C car? Thanks,Al W.
Photo below of the reworked firewall on an A/C car; the C60 firewall rework instructions/diagram and the installation of the adapter assembly that replaced the vent is shown in the Assembly Manual in section C60, sheets D1 and D2. The sheet metal blower & evaporator assembly can be installed without any issues - see sheet D5.
