Lost vin tag
Lost vin tag
A friend of mine lost his vin tag for his 66 caddy has owned the car for over 20 years and can't find any of his paperwork. Where or who can he contact to have a new one made????
On high value cars, there are people who will make new tags that are, in many cases, indistinguishable from the original. Their requirements for verifying the alternate VIN on the car are no different than most states and in some cases, are more stringent. Without the proper paperwork and inspections, it is going to be almost impossible to get the car back legal.
Regards, John McGraw
Well, being the type who wouldn't believe that someone who "can't find" their VIN tag is up to no good, I will point out one thing. If this was his car, and titled in his name and registered and kept legal all along, and he took it apart to restore it and couldn't find the VIN tag upon re-assembly (and I am also the type to not ask why the VIN tag was removed from its originally installed location in the first place), there should be no problem getting the VIN from the title or the registration, ordering a new tag and installing it. If a high quality reporduction is ordered, essentially no one will be the wiser.
The gentleman that I have used, requires a copy of the title in your name, an affidavit from a law enforcement officer in your state that he has inspected the alternate VIN, and pretty hefty check. If you can not furnish the copy of the title or the affidavit, then you need not worry about the check, as he is not going to make you a new tag!
Making VIN tags to order without the proper documents will almost assure the tag maker of a nice all expense paid vacation to the graybar motel sooner or later.
If the car is titled in his name already then it should be no problem to go down to the local DMV and ask for a duplicate title. At least it is that easy here in AZ. I am not sure when Cadillacs first started using VIN tags but I can tell you at least up until 1960 Caddys had no VIN tag on them...the DMV just inspects the frame rail where the VIN is stamped.
