Oil pressure problem saga
Morning Ladies and Gentlemen,
Continuing with the oil pressure problem on the L79 (66) . While waiting to install new oil pump, screen ( taking drugs to relieve anxiety ) and not having a gauge to test ring seal, ( coming soon thanks to Blockman ) I did a compression test on all cylinders this morning ( with pants on )
Rebuilt engine now has 325 miles on it
Results lbs
#7 185 # 2 185
5 180 4 190
3 182 6 171
1 175 8 185
Question remains on dark oil after start up and filter change (twice)
Just to keep members updated and for other suggestions
Jack
Results lbs
#7 185 # 2 185
5 180 4 190
3 182 6 171
1 175 8 185
Jack
Jack,
My thoughts, as from beginning,
1. I'm thinking that you'll see some improvement in oil pressure with the new oil pump.
2. I'm thinking your dark oil is from the engine setting for an extended period of time with the assembly lube inside, who knows what that was. But, I don't think it'll prove to be a problem.
3. Your cylinder pressures don't appear to me to be out of line.
4. Keep your chin up and your pants on, buddy!!
Ron
Ron
Received 1,843 Likes
You dark oil if from the assembly lube. Not from blowby. Nothing wrong with your cylinder readings.
I still think you have a plugged pump screen but somebody brought up a good possibility in your other thread. The relief valve could be stuck in your old oil pump which will also give you exactly the symptoms you have.
Maybe between all the old lube and a sub-par oil pump that would explain the pressure fluctuations....somebody prob already mentioned it but the pump pick up height in relation to the bottom of the pan is critical....so check the new one out carefully. Somebody smarter than me (MikeM?) on the topic may be able to provide more detail....
thanks all of you
Get a job or go for a ride, I would but the dam rain won't stop here in Maine, I don't have soft top on, but the sun looks like it may come out and what the hell,
15 pounds at 50 mph should be Ok
Jack
Too much time is what comes with retirement and only working part time, but I'm luvin' it!!!
And, part-time for me is just about right, especially when I get to pick and choose which part of the country (or overseas, now and then), I'm going to. And when it's a good location, the wife can travel along and we turn it into a vacation when the work's done.
I'm goin' for a ride in a couple of days, as soon as I get my new wheel bearing returned from Van Steel, coming tomorrow. ('Till then I'll drive the '65 coupe, although summertime is on the way in southeast Missouri, gotta get the top down on the '66!!)
This retirement is pretty damn great, like McDonald's, "I'm luvin' it!!"
Right on! I sit around my pool in FLA - gaze at the lake and work part time in my bathing suit... It was a long road and me and the 'ole lady started out 40 years ago without a pot to whiz in... Not Bill Gates but I do pretty much what I want every day..
When is the last time these cars ran for more than a day
Can I go on your next vacation?
I did go for ride, just used an umbrella to keep rain off head.....
Jack
Doug
I am not sure how your oil pick up is secured to the oil pump. Mine is a press fit and when installing the pan the engine builder must have bumped the pick up causing it to not be aligned flat to the bottom of the oil pan.
i now know that it is good practice to secure the pick up in position to the pump with a bit of weld.
it was very expensive for me to learn what my builder or his apprentice should have known........
I think when this thread started you said this was a fresh rebuild. Were the cam bearings replaced? This could cause low pressure if they were not replaced.
Dennis
Dennis
I want to say yew
I will have the pan off soon and we all hope it is just a clogged screen and the original pump, with a bad valve spring . The car has always had lowish pressure.
Jack
Received 6,529 Likes
C2 of Year Finalist (track prepared) 2019
With the cap off, you will be able to see into the oil passage leading from the pump to the filter. About an inch into this passage there should be a small Welch plug that separates this passage into "pre-filtered" and "post-filtered" sections.
If this Welch plug has slipped out of position, it could be partially blocking the oil path to the filter. Depending on how far out of position it is, there could be a dramatic effect on oil pressure.
FYI: There are some who believe that if this plug is missing entirely there will be an effect on oil pressure. I don't buy that since all its absence would do is to create a bypass path around the filter.
Jim
I personally don't know, but according to John Lingenfelter: "If the plug is missing the engine will lose as much as 20 psi because oil is leaking past this plug before reaching the rest of the engine. Idle oil pressure will be especially low. The missing plug can be mis-diagnosed as a weak oil pump, excessive clearances or any number of problems that will defy repair."
This is a qoute from the other thread as you can see the best leak down was 8% and the worst was around 35% and I would say the average was around 18% and on a newly rebuilt engine thats below standard. It was pushing air out of the crank case breather behind the intake manifold.
This is not the first engine I have seen where substandard work was done and only a leak down test will tell if you have good ring seal at TDC.
Just got back from looking at Jacks Engine and the reason why the oil was getting dark with only 100 miles is there is an issue with ring seal the best cylinder leaked down 8% and one was 10% and the rest were up to 35% leak down, Not good for rebuilt engine!!!
The oil pressure cold at idle was between 5 to 8 pounds with my gauge installed and the most I saw was maybe 20 pounds at around 2500 RPM. Could not hear any noises though.
On a rebuilt 327 if the clearances are right a Z-28 pump is more then enough with a small journal engine from what we have seen with these engines.
There going to drop the pan in 2 weeks so we should all know.
I can see by the pics that the bearing wear is not centered and most of the wear is on side of the bearing, Thats why I am a big advocate of line honing every block we go through as it also shows taper on the crank journal but where it was turned I would have to say the housing bore is tapered not the crank.
