Oil pressure question
Morning Gentlemen,
327/350 Original engine, 66 . Back from complete rebuild. Stared first turn of key. I have put on about 400 miles. Changed filter, after 1 hour, full of builder grease etc. Will change oil in about 100 miles. Live in Maine, so it is cold now. Pressure on start about 30 psi. Originial oil gauge. Goes to about 15 psi at highway speeds , drops to bottom of gauge at idle.
Have owned car for 40 years and I never had high readings, Could the gauge be old and reads low?
Is 15 psi ok at 30 to 70 mph ?
10/30 oil
Jack
10/30 oil
Jack
Received 4,573 Likes
2016 C2 of Year
2015 C3 of Year Finalist
15 PSI at highway speeds is way too low and certainly, "bottom of the gauge" or 0 PSI at idle when warm is off the charts. If the car runs well it's a safe bet that the gauge is no good.
Morning Gentlemen,
10/30 oil
Jack
10/30 oil
Jack
I wouldn't run it that way. Just my personal opinion. I would buy a cheap gauge that has a plastic oil line and hook it up to the engine. Just to check to see if the original gauge is giving you a correct reading. If the cheap gauge reads substantially higher I would guess that the original gauge does have some problems.
I will get second gauge to check it
Will verifiy with other gauge
Engine runs like clock, no valve noise or indications of not getting oil, but I agree it does not make me feel good to see no pressure at idle, could the gauge have gotten gunk in it upon start up, from rebuild?
Jack
is there a fitting on the front of the block between the water pump and intake??..if so it is an oil tap....
Good luck and let us know how you make out,
Yes there is a square bolt in that place
Run both gauges at same time to see if old gauge is off?
Thanks for tip,
I will get back with readings as soon as I put my pants on
Jack
naaaah...do it without pants......yes BOTH gauges
Could oil pickup screen be blocked with gunk?
I know you do not want to read this but I would verify oil gauge (as already stated several times) immediately, but be prepared that you might have a engine issue which is not common but it does happen. Your description is exactly what engines do when they have issues, not a faulty oil gauge. I hope it is the gauge but if it worked fine before I would be checking it but preparing for more drastic issues. I would not run the engine anymore than you have to check the gauge. Easier to fix than wasting away journals, etc....
Jack
AMA Specifications (Automaker Manufacturing Association) for the Chevrolet 327 engine show 30-45 psig at 1500 RPM for normal (hot) operation.
My 1967 327/350 HP has around 50-60 psig cold at startup, 45-50 psig hot normal running, and 30 psig hot idle.
Larry
Larry
Received 1,844 Likes
The AMA specs as quoted above are "normal" for a 327/350 engine.
Oil pressure problem results
Was not able to get square nut off front oil tap. Water pump in way and no socket to fit, brass nut and started to strip if worked to hard
Use regular fitting at rear that supplies reg gauge
Other gauge showed same reading. 5 or less at idle 15 max at faster rpm cold, did not wait to warm up since I know what to expect.
The car has always read a bit low, even 40 years ago. 30 to 40 psi max
about 15 to 20 warm. and would drop low at idle. Engine has over 250,000 miles on it with same pump and reading but Never dropped to almost 0 at idle
The lube used for assembly was LubriMatic Motor Assembly White Grease.
Lots of gunk in first filter after 1 hr run time
Oil is clean, no smoke or bad sounds that I can perceive
Engine feels strong like I remember when I was 22 and bought car
I don't believe he changed original oil pump.
Only leak front of oil pan stated below
I did put on a spin filter instead of original canister.
I do have a small leak front of oil pan and I am going to have gasket replaced next week and will have screen and pump checked
If you believe the pump may be problem, since I will be dropping pan no problem with putting in new pump (I hope that is problem)
Car temp is at 160 after warm up. New Dewitt direct fit rad. Old temp was at 200 plus before rebuild with 20 year old copper.
Could I have put on spin filter wrong.. Does not leak or indicate any problem
I will not run engine until I hear your comments
Jack
Thanks all of you for your comments. I will give you the results of my test and some of the things done to engine.
Jack
Jack
Little changes, won't cost much, and will eliminate any possibility from the equation, in my opinion . . .
the builder should have replaced the oil pump......get a MELLING high volume not high pressure....be sure you still have the original filter plate used in conjunction with the spin adapter!! ....you won't need to go back to the canister..this should solve your problem....disconnect the idler arm at the 2 bolts on the frame...then you can pull the center link down to make pan removal easier..good luck....
I would replace the oil pump with a standard replacement pump while you had the pan off but I don't believe that's your problem. Pumps wear and will lose pressure but they don't do it sitting on the bench waiting for the rebuild to be complete. If you put a new pump in, tack weld the pickup screen to the pump housing. Don't rely on the press fit.
I'd like to tell you something happened when you changed the oil filter over but I have no idea what it could be if it doesn't leak.
Good afternoon Gentlemen
Anyway, guess what? no change, still low pressure.
I think I will keep the canister for a while.
Now, heaven forbid, if I change the pump, and still low pressure....
Is there any possibility that the oil tap opening, could be clogged in any manner from the build, or if that was so, would I not see any pressure on the gauge,
It still goes up and down , just not up as far as I would like, like a lot of things at our age.
Jack
Last post and I am having a good drink
I will let you all know the outcome of a new pump.
Now a drink and little TV golf watching. Good to see others frustrated, I think I will take my pants off , since putting them on didn't fix my problem
Jack
