How to possibly remove tar undercoating
Old 03-25-2009, 11:22 AM
Don Schuette
Don Schuette's Avatar
Default How to possibly remove tar undercoating
I have a light coat of black tar-like undercoating on the entire undercarriage.
Any ideas on various ways of removing this?
Is soda blasting an option?
Thanks in advance,
Don
Old 03-25-2009, 11:30 AM
Mike Geary
Mike Geary's Avatar
Default This works well
If there's some thickness to it, first heat it and scrape off as much as possible. Use a plastic or wood scraper.
Then, spray on some kerosene, let it work, and wipe off. Scotch brite pads might be necessary.
If your coating is tar-based --this will take it all off, leaving the 'glass looking like new.
Old 03-25-2009, 11:35 AM
Ron Miller
Ron Miller's Avatar
Diesel fuel also works well, usually cheaper and easier to obtain than kerosene as well. DON'T use gasoline . . . .
Old 03-25-2009, 07:18 PM
DansYellow66
Support Corvetteforum!
DansYellow66's Avatar
Received 2,629 Likes on 1,960 Posts
Eastwood makes an undercoating remover that is in an aerosal can. Reports I've read on it indicate it works pretty well.
Old 03-25-2009, 07:24 PM
Tintin
Cartoon Character
Tintin's Avatar
I used to take the tar like sound deadening material and undercoating of showroom stock cars that I raced in Firehawk and World Challenge very easily and without chemicals. You put the car outside in the winter (it worked in Canada and will work in Nebraska for sure.) The stuff freezes and you can tap it with a tack hammer and it shatters. I used to get almost 200 pounds out of the car like that..
Old 03-25-2009, 09:23 PM
GreaseMonkey
GreaseMonkey's Avatar
PA Events Coordinator
WD-40 works too....
Old 03-26-2009, 01:12 AM
o2bnkc
o2bnkc's Avatar
When we're paving roads, and we need to get it off our trucks (or anything else), the only way to go is use diesel fuel.
Old 03-26-2009, 09:14 PM
Ol Blue
Ol Blue's Avatar
I used a heat gun and a scraper to remove the majority of undercoating and then used wd40 and scotchbrite pads for finish work.
I put my hand on the outside of the fiberglas so I could feel the heat and not let it get too hot.
Ol Blue
To How to possibly remove tar undercoating
Quick Reply: How to possibly remove tar undercoating
