Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-06-2009, 07:59 AM   #1
wmf62
CF Senior Member
St. Jude Donor '07
Support Corvetteforum!
wmf62's Avatar
Default 1970 LT1 torque/horsepower curves
does anyone have, or know where i can find, dyno graphs of the torque/horsepower curves for a stock 1970 LT1?
Bill
wmf62 is offline   Reply With Quote
Old 03-06-2009, 08:20 AM   #2
Shurshot
CF Senior Member
Have you asked in the C3 section?
If that does not pan out or there are not any good replies here I would suggest going to http://www.speedtalk.com/forum/.
Doug
Shurshot is offline   Reply With Quote
Old 03-06-2009, 09:02 AM   #3
mashinter
CF Senior Member
mashinter's Avatar
Quote:
Bill
Bill:
These are published in Best of Corvette News, p. 579
Bill
mashinter is offline   Reply With Quote
Old 03-06-2009, 09:11 AM   #4
wmf62
CF Senior Member
St. Jude Donor '07
wmf62's Avatar
Bill
thank you very much, i would have never thought to look in there (haven't looked at that book in years.... )
Click the image to open in full size.
Bill
Old 03-06-2009, 05:17 PM   #5
vetrod62
CF Senior Member
vetrod62's Avatar
Bill
Bill
Those graphs are bogus. HP and TQ have to cross at 5250 rpm.
vetrod62 is offline   Reply With Quote
Old 03-06-2009, 07:11 PM   #6
Shurshot
CF Senior Member
Quote:
Good eye
As soon as I realized that I could not read the print without a magnifying glass I gave up....... but for sure if they do not cross at 5250 they do not reflect a real dyno run on a real motor....... more like a sales department clerk's handiwork
Doug
Old 03-06-2009, 07:22 PM   #7
Zigler
Junior Member
Take a closer look at the scales. The torque (ft-lb) and power (hp) only cross when they are both plotted on the same scale. 5252 is only a conversion factor; 1 hp = 5252 ft-lb * 1 rpm = 1 ft-lb * 5252 rpm. There is nothing magic about crossing at that number and being a "real" plot. It only means power and torque are plotted using the same scales. They weren't for these plots.
Cheers,
- Brad
Zigler is offline   Reply With Quote
Old 03-06-2009, 08:06 PM   #8
jim lockwood
CF Senior Member
jim lockwood's Avatar
Zigler is absolutely correct.
Look at the torque on the right hand scale at what you interpolate to be 5250..... it's something less than 360 ft-lbs.
Now look at horsepower on the left hand scale at the same interpolated 5250 RPM and you get something less than 360 HP.
There's your mandatory "crossover".
Jim
jim lockwood is offline   Reply With Quote
Old 03-06-2009, 08:32 PM   #9
wmf62
CF Senior Member
St. Jude Donor '07
wmf62's Avatar
Default Biiger graph
i was trying to keep people from having to pan sideways.
yes, there are different scales on the right & left sides.
the reason i asked was that with a 3.36 rearend and a .73 OD,
the normal rpm range that my LT1 operates in is 1500 to 2500
and i was trying to determine what the most efficient operating
'sweet spot' was for that engine
Bill
Old 03-06-2009, 11:35 PM   #10
Shurshot
CF Senior Member
Jim
With the larger print I can see what you and Zigler are saying
Ok...... my bad :o
Doug
Old 03-07-2009, 01:49 AM   #11
Solid LT1
CF Senior Member
Solid LT1's Avatar
I like the fact that the LT-1 HP is still climbing at 6000RPM where the LS-5 is laying down at 5100RPM. You should remeber the early SAE testing was done with a 30/30 cam and not the LT-1 solid cam, many think the LT-1 gives away 10-15HP from the SAE test. My 70 LT-1 needs to get to 2200-2400RPM before she is really happily running (possibly because of running pump gas+additive when running on 30% race gas/pump gas mix she is much happier.)
Solid LT1 is offline   Reply With Quote
Old 03-07-2009, 09:03 AM   #12
wmf62
CF Senior Member
St. Jude Donor '07
wmf62's Avatar
yep, that's about what i figure, i find myself trying to keep above 2000
by driving in 2nd or 3rd around town and not using OD until i get above
55 (which just almost gets to 2000. 75 is just about 2250). the Rochester
FI handled it well on leaded gas in the summer. but for as much as i drive it
would be too expensive to use racing fuel, even as a mixture (and i would
have to drive 20 miles just to get some...)...
Bill
Reload this Page 1970 LT1 torque/horsepower curves
Tags
1970, 1970lt1, 1996, 5250, cam, corvette, crossover, curve, dyno, horsepower, lt1, plot, rpm, torque, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
