harmonic balancer
harmonic balancer
Just recieved my harmonic balancer for Paragon. (8 inch, non-finned) I assume they come balanced. Am I right? Looks like it's been drilled in three spots by the Mfg. I'd like to paint it right away to avoid surface rust.
Received 1,844 Likes
You should assume it's been balanced and ready to install. However, you could be assuming wrong. I'd have it checked. It won't cost that much.
Nah, I changed my mind. I probably wouldn't have it checked for balance if it had some balance holes drilled in it. If there were NO signs of a balance job, I'd definitely have it checked.
Received 3,773 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
For those who may not be familiar with the UNbalanced balancers, here they are:
454
SB400, compared to an 8in 350 balancer (also required when building a 383 from a 350 block and 400 crank).
Tom Parsons
454
Tom Parsons
