Corvette Forum
Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-21-2008, 02:03 PM   #1
petew
Junior Member
petew's Avatar
Default 1966 Vette Exhaust Manifolds
My car still has the original 327/350 engine in it which runs great but I am contemplating removing it for safe keeping and installing a 383 in its place. The plan would be to dress the engine in as many of the original parts as possible to maintain a "stock" outward appearance. I know about the breather issue and have veiwed the various threads showing the options available. I figure that I should probably replace the stock 2" 1966 exhaust manifolds with a pair of 1965 2 1/2" manifolds. The question is my 1966 has the alternator on the driverside and the 1965 has it on the passenger side, so...... Can the 1965 2 1/2 manifolds be used and still maintain the stock (driver side) alternator location ?
Pete
petew is offline   Reply With Quote
Old 11-21-2008, 03:33 PM   #2
JohnZ
CF Senior Member
Support Corvetteforum!
Quote:
Pete
Yes - just use the '65 2-1/2" driver's side exhaust manifold that was used with A/C; casting #3846563; it uses your existing lower alternator bracket and upper alternator brace. Use casting #3797902 on the passenger side.
JohnZ is offline   Reply With Quote
Old 11-21-2008, 10:11 PM   #3
petew
Junior Member
petew's Avatar
John,
Thanks for the info. I found a 3797902 and a 3797901. Will that pair work or only the 3797902 ?
Pete
Old 11-22-2008, 04:59 PM   #4
JohnZ
CF Senior Member
John,
Pete
The 7902 is for the RH side, and the 7901 won't work for the driver's side - it doesn't have the two forward-facing tapped holes for the lower alternator bracket; you need a 6563 for the driver's side.
Old 11-22-2008, 06:49 PM   #5
petew
Junior Member
petew's Avatar
Thanks again John, I'll be looking for the 6563 and the 7902.
Old 12-08-2008, 01:31 PM   #6
petew
Junior Member
petew's Avatar
John,
Found and purchased the 3846563 for the driver side. I also located a 3797942 ...would that work for the passenger side ? It is listed as a 1965 327/365hp right side manifold.
Pete
Old 12-08-2008, 04:12 PM   #7
JohnZ
CF Senior Member
Pete
Yup, the 942 will work fine.
Reload this Page 1966 Vette Exhaust Manifolds
Tags
1966, 2, 3797902, 6563, casting, corvette, manifolds
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Fastest "stock" Vette of all time ? kenmo C1 & C2 Corvettes 64 10-23-2002 10:41 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
