Replacing Temp sending unit.....
Used the IR gun and found the sending unit is reading 25 to 30 degrees higher than actual temp.......SO- where can I find the particular sending unit I've seen mentioned on the forum?? TU-5 or something like that... AND- do I need to drain any coolant prior to removing the old sending unit?? Thanks very much for any advice..
You can buy it at Auto Zone. It use to be the Wells TU5. I think they now call it their store brand name which is Duralast. It worked for me. You don't have to drain your coolant to change the sending unit.
PS - I am glad you may have found the temp gauge readings themselves to be the issue, rather than a persistant run-hot condition as you first feared:
http://forums.corvetteforum.com/c1-a...questions.html
They seem to be hit or miss on whether or not you will get one that reads accurate.
I ended up finding a guy locally that had a couple used original GM temp sender units and bought them. After measuring the OHM's with a meter I choose the one that read closest to what it should be and used it. It's accurate within about 7º. Not perfect but a whole lot better than the 40º off I got with the Wells TU5.
Other people have had luck getting a TU5 units though that worked for them so like I said, it seems to be hit or miss.
buy two, I had to try more than one to end up with one that works well-enough with my temp gauge to provide basically accurate readings.
LectricLimited now has temp sending units that they claim are more accurate than the OEM tolerance. While I haven't personally used one of them, their company reputation is quite good, as is the quality of their harnesses. You might want to check it out:
http://www.lectriclimited.com/mainpage.htm
