Any tips for wiper arm removal?
Old 08-07-2020, 05:15 PM
JLMICCA
JLMICCA's Avatar
Default Any tips for wiper arm removal?
As the title says, any tips on wiper arm removal? I'm actually working on a '66 GTO but the wiper arms look similar to my C2. There is a little metal tab just under the arm near the shaft. Do I pry it down with a screwdriver? I have a wiper blade removal tool but think it is more geared toward Ford wiper arms. It's the type shaped like the letter L with a tab on one end that hooks on the arm end and pries over the top of the arm. This car is fresh out of paint and one arm is on wrong and goes too far down onto the cowl.
Old 08-07-2020, 05:22 PM
roberts427
Support Corvetteforum!
roberts427's Avatar
I have the tool that LIC sells works great for the corvettes.
Old 08-07-2020, 05:50 PM
DZVette
DZVette's Avatar
See if you can find the tool at a local parts store "Help" section.
Zoomin (08-07-2020)
Old 08-07-2020, 07:35 PM
silver837
silver837's Avatar
I bought that tool and could never get it to work. I finally used a paint can opener. I started a thread about it. If you click on my users name you can look up the thread. The tool wouldent work because there was a build up of overspray in the splines for the wiper heads,
My post was on 6-5 2017
Old 08-07-2020, 08:07 PM
65hihp
65hihp's Avatar
Received 3,268 Likes on 1,689 Posts
Tool is so easy to use it's scary. When you have the tool and the arm pulled up together, just wobble a little bit as you lift, and up she pops.
Old 08-07-2020, 09:24 PM
smacota1
smacota1's Avatar
One of the best tools I ever bought. Easy peasy
Old 08-07-2020, 11:33 PM
silver837
silver837's Avatar
Originally Posted by Wayne88
When you are wiggling it off, It may pop off all of a sudden and slip out of your hands and scrape something. When I used it, I put painters tape on the grill just in case,
I used an old bath towel with holes cut to protect the paint and SS trim.
Old 08-08-2020, 11:09 AM
LouieM
LouieM's Avatar
Received 3,039 Likes on 1,252 Posts
Agreed. A bit of handy-dandy perfection.
dcamick (08-08-2020)
Old 08-08-2020, 12:05 PM
JLMICCA
JLMICCA's Avatar
Thanks guys. That's exactly the tool I have but my first attempt didn't work well. Like the idea of the tape where you (Hinkley) indicate. So I take it, no need to mess with that little metal tab? (See Pic)
Little tab on the arm end by the shaft...do I need to mess with it to allow the arm to pull off?
Old 08-08-2020, 12:11 PM
65hihp
65hihp's Avatar
NO. Disregard the tab. Use tool as shown in Post 3. Wobble just a bit as you lift. That's it.
Old 08-08-2020, 04:38 PM
DansYellow66
DansYellow66's Avatar
Received 2,620 Likes on 1,952 Posts
Tape and towels. They pop lose sometimes suddenly and motor control skills don't always react quick enough.
bcwaller (08-08-2020)
To Any tips for wiper arm removal?
Quick Reply: Any tips for wiper arm removal?
