65 396 "962" block
#41
Received 6,975 Likes
2015 C2 of Year Finalist
#42
Received 1,859 Likes
Their schedule depended on the forecasts from the order banks at all the various car and truck assembly plants; they probably batched where it made sense on a given day, but all big-blocks went down the same line.
#43
#44
#45
So this one could properly be used in a 65 L78-car Corvette?
Since "all 962 blacks are the same" (gussets excluded), there must be a second clutch boss hole forward.
#46
I'm not familiar with the 961 block - it wasn't used in Corvettes; having gussets or not could be a random foundry error by using the wrong front pattern when the mold was packed.
#47
#48
John -- Colvin's Chev-b-t-Numbers '65-9 shows blueprint of front view of a 961 bock (top of pg 60), and the two gussets show clearly. There's even a section (side view) EF-EF through one of the gussets [shows the passenger side gusset 1.88" right of engine centerline], the details of which must be on another drawing.
#51
If the block does not have front and rear gussets, it is not an original 396 corvette block. It may work in other Chevy models.
Bill
Bill
#53
No - The gussets must be front and rear.
Bill
Bill
