Share your experience please
How do I find out what equipment, engine and options my car came off the line with. I've found how to chweck paint, trim and engine #'s but but what tells me what it came with? Thanks for helping!
What year are you talking about? The word "trim" in your post suggests a 63-67?
For the most part, all you can do is use detective work to see what things are in place, what evidence there is that other things were in place. Use the tachometer or other gauges to help determine what horsepower those gauges were for, and then if you are lucky and those gauges have a ink-stamped date code that closely aligns with the production date of your car, you have a high probability that those gauges are original to your car and actually tell you something about - your car.
My 66 coupe shows all the signs that it was a big block high horsepower car. The gauges seem to be original as I had the dash out not long ago and it all seems to match. My battery is located on the Passenger side though?
A 66 BB with air will have a low red line tach and a 2 bolt 427 hydraulic cam engine with a Rochester 4 bore carb. Probably also have a cast iron intake...
Received 7,016 Likes
2015 C2 of Year Finalist
only a 65 L78, and any car with A/C had the battery the driver's side.
