Corvette Forum
Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-18-2008, 10:02 PM   #1
Low Rider
CF Senior Member
Support Corvetteforum!
Low Rider's Avatar
Default Air Conditioning a C1
Probably a frequent ask question but being a new C1 owner I don't get on this forum much. Anyway I just bought a 57 that is under construction. It was a old race car and only has 58K on it, It will be a resto rod with Fatman suspension, blown 355 etc etc (Please not flaming) My wife wants air in the car so I gotta get it. Which manufacture has the best unit for the C1? I had a Vintage Air in a street rod and was well satisfied with it but wanted to check with the experts first (you guys) to see which one you liked. Thanks for the info.....
Low Rider is offline   Reply With Quote
Old 07-18-2008, 10:35 PM   #2
Stan's Customs
CF Senior Member
Quote:
...I haven't made a choice yet but I am seriously considering this because the case is screwed together rather than glued and repair parts can be bought and replaced...and it has a large evaporator (they call it an a/c coil). Also the system is controlled using the original heater control panel for all of the air diverter doors and air temperature changes.
http://www.classicautoair.com/Corvette.asp
Good luck...Stan..
Stan's Customs is offline   Reply With Quote
Old 07-18-2008, 11:19 PM   #3
wmf62
CF Senior Member
St. Jude Donor '07
wmf62's Avatar
Hot Rod Air... somewhere on here is a thread about mine and others install...
here it is....
http://forums.corvetteforum.com/show....php?t=1540091
Bill
wmf62 is offline   Reply With Quote
Old 07-19-2008, 12:23 PM   #4
56 Texas
CF Senior Member
56 Texas's Avatar
I have the Classic Auto Air unit on my '56 and have been very happy with it ...
56 Texas is offline   Reply With Quote
Old 07-19-2008, 12:56 PM   #5
Low Rider
CF Senior Member
Low Rider's Avatar
Quote:
Classics intro sheet on their web site only shows 58-62? Do they actually have a unit for the 56-57s?
Old 07-19-2008, 01:00 PM   #6
Low Rider
CF Senior Member
Low Rider's Avatar
Hey thanks guys, I will check out each suggestion and I am sure I will have more questions on other stuff as I said I purchased the car in process but paid to have it completed so I got lots of questions.
BTW from looking at you avatars you have some way cool cars there.....
Old 07-19-2008, 02:40 PM   #7
DZAUTO
CF Senior Member
As of now---------------to the best of my knowledge, there is NOT a 56-7 specific AC system available. Although, if you're pretty good a fabricating/modifying, it should be fairly easy to adapt a 58-62 to fit the 56-57.
I have wanted air in the 56 for many, many years, but I just haven't been able to do the mods to the car.
Also, I DO NOT want to eliminate the stock, factory 56-7 heater system, so if I were to add air, I want an air ONLY add on system.
One last thing, I want to retain the "original" look of a generator. There is a guy in Tex who can supposedly modify a generator to put out about 40amps, which should be adequate for an add-on air system.
So, why don't I want to convert to an alternator? Like I said, I want to retain the look of a generator.
DZAUTO is offline   Reply With Quote
Old 07-19-2008, 07:16 PM   #8
LabRat
CF Senior Member
LabRat's Avatar
DZAUTO perhaps this would help someday. It looks like a generator but is an alternator. Save the Wave.
LabRat is offline   Reply With Quote
Old 07-19-2008, 07:16 PM   #9
LabRat
CF Senior Member
LabRat's Avatar
DZAUTO, oops I forgot the link. http://www.gener-nator.com/ Save the Wave.
Old 07-19-2008, 09:50 PM   #10
vetrod62
CF Senior Member
vetrod62's Avatar
You might want to rethink the AC. Blown engines run real hot and C-1s do not have a real large area for the radiator. Look at all the threads with stock engines that run too hot.
vetrod62 is online now   Reply With Quote
Old 07-21-2008, 01:53 AM   #11
56 Texas
CF Senior Member
56 Texas's Avatar
they used a universal street rod unit and made it fit like it was made for it .. has AC, defrost and heat .. works like a new car .. took repro ***** for the dash and made them fit the new controls .. I have a Be Cool radiator and Keisler 5 speed - the car is a joy to drive .. even in the Texas heat!
Old 07-21-2008, 07:39 AM   #12
tomply32
CF Senior Member
tomply32's Avatar
Default c1 corvette air
we put a unit from southern air aka southern rods in my 61 vette .small block with blower .worked great with no overheating and it gets hot in south florida.the secret is have a good quality rad/fan set up and use a condenser/fan assm. remotely in rear above the axle (there is room) we had a narrowed 9 inch .if this is attempted condenser cannot be flat has to be on an angle .unfortunatly no pics of underside car has been sold and went to texas.oh and also use the best a/c hose you can buy i heard there is a grey hose that is used in buses because of the length cheap hoses will have you recharging every 2 or 3 years.good luck
tomply32 is offline   Reply With Quote
Old 07-21-2008, 01:29 PM   #13
Black60
CF Senior Member
Low:
Congratulations on your new project.
I used Hot Rod Air and am happy with it. However I never run with the top up unless it is raining. In retrospect I should have put the money into restoring my hard top.
I suggest you consider insulating the heck out of the interior. I installed Dyna-Mat inside of the car from the windshield retaining bolts, down the firewall, along the floor and up behind the seats. I'm in a cocoon of Dyna-Mat. It is rubber based, does not absorb water and installs almost too easily. By that I mean once you peel the paper off of the sticky side make sure you place it where you want it. There is little or no adjustment once it sticks. A fabulous side benefit is that it water proofs all those little holes and seams we all have in our floors and fire walls. I get no water during rain events except from my windshield convertible top joint.
It keeps the road heat away from you as well and deadens the sound making the car a pleasure to drive.
Best Regards
Black60 is offline   Reply With Quote
Reload this Page Air Conditioning a C1
Tags
07, ac, air, c1, c1corvette, c2, condition, conditioner, conditioning, corvette, corvettes, find, reviews, vett, vette, vintage
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
c1 guy wishes advice from c3 guys STEVES59 C3 Tech/Performance 17 07-01-2004 07:39 PM
FS or Trade for C1/C2: 1996 Corvette Grand Sport Coupe shollis C4s for Sale/Wanted 13 05-11-2004 06:13 PM
How about a Corvette Classic along with a new C6? H82BFST C6 Corvette General Discussion 49 12-22-2003 04:44 PM
C1 with big block cbernhardt C1 & C2 Corvettes 12 07-22-2003 08:52 AM
Questions from a potential C1 purchaser Captain Kirk C1 & C2 Corvettes 20 12-26-2001 01:43 PM
Should I get a C1 or C2? Captain Kirk C1 & C2 Corvettes 29 11-11-2001 03:07 AM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
