Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-03-2008, 12:34 PM   #1
gonefishn
CF Senior Member
St. Jude Donor '09
gonefishn's Avatar
Default Starter/solenoid current draw (amps)
Does anyone know much current the starter/solenoid draws when cranking?
Thanks,
John
gonefishn is offline   Reply With Quote
Old 07-03-2008, 01:00 PM   #2
Plasticman
CF Senior Member
Plasticman's Avatar
Send a message via ICQ to Plasticman Send a message via AIM to Plasticman
Nope. But if you have an Ohm meter (VOM or DVM, etc.), it is an easy calculation to make on the solenoid.
Current (I) is equal to Voltage (V) divided by the Resistance (R).
Measure the Resistance of just the solenoid coil, and divide into 12 (for nominal voltage while pulling in the solenoid).
Example: If you see 6 ohms, divide 6 into 12 (for volts), equals 2 amps.
Note that the solenoid draw will be nowhere near the actual starter motor current draw. If I was to guess, I would say somewhere under 10 amps (judging from the wire gauge that supplies current to the solenoid).
As for how much the starter draws, I have "heard" up to 300 amps depending on a lot of factors (ambient temp, oil viscosity, size of engine, starter windings, etc.).
Plasticman
Plasticman is online now   Reply With Quote
Old 07-03-2008, 01:09 PM   #3
mechron
CF Senior Member
yep, 175 to 250, the lower the better. amp tested starters for years, about 200 is the norm...
EDIT: this is the amp draw through the bat cable with the starter motor cranking,just to be clear.
mechron is offline   Reply With Quote
Old 07-03-2008, 01:29 PM   #4
Matt Gruber
CF Senior Member
yep, my 61 is 200.
Quiz: who else can measure it with a $3-10 DVM ?
Matt Gruber is offline   Reply With Quote
Old 07-03-2008, 01:41 PM   #5
mechron
CF Senior Member
Quote:
Originally Posted by Matt Gruber View Post
yep, my 61 is 200.
Quiz answer: Matt, i use snap on inductance ammeters. they have a U shaped channel on the back of the gauge, you just lay it over the outside of the cable and it reads the current running through the cable. it takes about 2 seconds...
Old 07-04-2008, 12:09 PM   #6
gonefishn
CF Senior Member
St. Jude Donor '09
gonefishn's Avatar
Thanks everyone. The problem I'm trying to solve is a hot start problem with the starter and/or solenoid (when hot no cranking).
Have about 0.4 - 0.5 ohm resistance so at 200amps so I think my problem is too large of a voltage drop to engage the solenoid. (Very embarrassing when I can't restart the car until it cools down).
Old 07-04-2008, 01:52 PM   #7
Plasticman
CF Senior Member
Plasticman's Avatar
If the solenoid is not pulling in (when hot), you have a few options:
1st I would check the wiring to the solenoid for frayed strands (from the ignition switch), poor connections, etc.
2nd Would try a new solenoid, or the lighter solenoid spring that I have seen mentioned elsewhere.
3rd, I have had good success on another vehicle with just changing to heavier gauge wire to the solenoid (less voltage drop).
If the starter is turning over, but is just heat soaked (weak from heat), then a heat shield would be in order, or a stronger starter.
Plasticman
Old 07-04-2008, 02:18 PM   #8
gonefishn
CF Senior Member
St. Jude Donor '09
gonefishn's Avatar
Thank you for the good ideas.
Was considering the stronger starter. My understanding is a OEM start only has about ~180ft-lbs of torque. When normal temperature it turns the engine over slowly and fires after about 2 - 3 turns. But when hot (immediately it restarts but after 10 min it won't) the starter won't even engage.
Will recheck the solenoid and connections to ensure they are good.
Also, does a heat shield really work well? Seems so hot down there it is hard to believe it reflects that much radiant heat. This would be the best approach and turn me around as a skeptic.
Old 07-04-2008, 02:58 PM   #9
mechron
CF Senior Member
if i understand what you are saying correctly--NO cranking at all sometimes when hot. replace the solenoid, there is a break in the pull in windings. classic chevy starter problem. if there is a drop in voltage through the solenoid--REPLACE THE SOLINOID once again, the copper washer that connects bat voltage to the starter is pitted. in short, replace the solenoid, it's a simple job...
Old 07-04-2008, 03:04 PM   #10
Plasticman
CF Senior Member
Plasticman's Avatar
If you have headers, yes a heat shield works well. If no headers, should be no reason for one. Depends on how close the pipes are to the starter/solenoid. I do have headers and have not needed a shield, but have seen applications where that was the only way the starter would work when hot.
If your starter is turning over slowly when cold, might want to try a new starter. It only gets worse when hot due to heat losses in the starter and solenoid windings. Or at least take it down and inspect it for worn brushes, etc.
Another thing I have done is to increase the size of the positive cable going to the starter/solenoid (from the battery). It made my starter turn over much faster. Also check your ground cable and connections as well.
Plasticman
Old 07-04-2008, 03:10 PM   #11
mikem350
CF Senior Member
OK Mat, how do you measure the starter amp draw w/ a cheapie DVM???
mikem350 is offline   Reply With Quote
Old 07-04-2008, 03:17 PM   #12
Plasticman
CF Senior Member
Plasticman's Avatar
Quote:
Would need to go through a shunt resistor (low ohm/high wattage resistor), and then measure the voltage drop across the resistor to calculate the current.
Plasticman
Old 07-04-2008, 04:35 PM   #13
Matt Gruber
CF Senior Member
just measure the v drop on the heavy starter wire cranking, then the v drop headlights on only.
then headlight amps(up to 20)
v drop is directly proportional (starter wire is the shunt) or use battery to ground as shunt
Old 07-04-2008, 07:35 PM   #14
mikem350
CF Senior Member
Thanks, Mat, I get it!! Will explain for posterity.
The bat cable acts as the shunt, and you will be reading small voltages (actually they better be else cables are bad ).
Then using the amp function directly measure the lights (pull the fuse and use 20 amp scale or higher) and compare. I would calculate the shunt resistance value R=V/I and repeat the V drop test for cranking
Old 07-05-2008, 08:12 AM   #15
Matt Gruber
CF Senior Member
good.
Not to knit pick, but there is no need to calculate R.
use a solve for x equation
ie if
20 amp = 0.2v,
a 2.0v drop is how many amps?
answer 200
that example is easy enough to do in your head.
Note: cranking amps may be lots lower than starting amps. IIRC starting was ~300 on my 61. This is due to my aggressive spark advance.
If anyone wants to chime in with their results it would show they can really do it.
Hint:turn on enough stuff to get 12-16 amps; $3 DVM meter on 10a scale will read that ok.
The poster should check all connections for v drop. Ground to frame often overlooked and corrodes
Reload this Page Starter/solenoid current draw (amps)
Tags
54, amp, amperage, amps, chevrolet, chevy, current, draw, motor, pull, selonoid, solenoid, starter, typical, volt
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
