oil filter of choice
Old 07-01-2008, 09:04 AM
old cars
old cars's Avatar
Default oil filter of choice
Hi guys,
I just purchased a spin on oil filter conversion for my 66 327.what is the filter of choice brand and part #.The guy at Paragon said pf25 or 35 works and the I also heard a autolite filter works.I appreciate any info.
Daryl.
Old 07-01-2008, 09:29 AM
Donald #31176
Donald #31176's Avatar
I prefer US manufactored filters such as Wix, Baldwin and some Purelators.
Old 07-01-2008, 09:33 AM
6T5RUSH
Support Corvetteforum!
6T5RUSH's Avatar
Cruise-In III Veteran
old cars,
Here's an archived thread on this very topic. Good read. I use the BALDWIN line of oil filters...specifically #1428 for my 327.
http://forums.corvetteforum.com/show...WIN+OIL+FILTER
Good luck in your decision.
Regards,
Jim
Old 07-01-2008, 09:34 AM
Jims66
Jims66's Avatar
K&N......., it also has a nice 1 inch bolt welded to the bottom for easy removal !!
Nickrnic (08-14-2022)
Old 07-01-2008, 09:50 AM
66BlkBB
66BlkBB's Avatar
St. Jude Donor '13-'14-'15-'16-'17
What's wrong with AC filter??? That is what I use on all my units. Are they not US made?
Steve
Old 07-01-2008, 09:56 AM
Donald #31176
Steve
Compare the construction of a current AC 1218 and equivelent Fram HP2. They seem to be the same and Frams are offshore built. The Purelator plant in Tenn and the Baldwin plant in Kearney, Neb I have heard are the only plants making oil filters in the US.
Old 07-01-2008, 10:17 AM
Kensmith
Kensmith's Avatar
I like the PF-35 as it is a larger filter.
Old 07-01-2008, 10:45 AM
CaveCreekChump
CaveCreekChump's Avatar
Default Wix for me!
Years ago I saw a cutaway demo of all major filter brands and Wix definately inspired the most confidence.
Also, I like max oil capacity so I use the two quart Wix 51794.
Old 07-01-2008, 10:51 AM
1snake
1snake's Avatar
I use Baldwin filters on everything.
Jim
Old 07-01-2008, 11:07 AM
DZAUTO
DZAUTO's Avatar
Received 3,772 Likes on 1,674 Posts
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Absolutely, 100%, .
That's all I use. The WIX 51794 is actually a truck application, but is totally interchangeable with the shorter filters (just more filtering capacity). And, no need to worry about its additional length. The bottom of the filter is just about even with the bottom of the oil pan, thus, nothing hanging down lower.
Old 07-01-2008, 11:09 AM
67-427ci
67-427ci's Avatar
I use Baldwin filters, but there are many other quality filters. Check out this analysis of oil filters done a few years ago.
Oil Filters Revealed
Don't know how accurate it is, but it is interesting reading.
Roy
Old 07-01-2008, 11:14 AM
1Redctoo
1Redctoo's Avatar
Default oil filter
Daryl- I see you said "conversion" . I'm currently taking apart my '66 327 engine and noted that the oil filter is a large center bolt type that fits in a recess in the block . Is yours like this ? I'd like to convert my to a spin on type if possible .
Old 07-01-2008, 11:38 AM
JCZ33
JCZ33's Avatar
AMSOIL, good for 9K.
Old 07-01-2008, 01:01 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
The PF-25's are getting hard to find so I was running a PF-1218 for a while until I found a NAPA brand replacement for the 1218 that is long and black...nearly looks like the old cannister itself. I don't have the NAPA part number handy right now. A little hard to see in this pic but you get the idea:
1Redctoo - here is what I used:
http://www.ecklers.com/product.asp?p...75&dept_id=153
Old 07-01-2008, 01:33 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
Originally Posted by DZAUTO
Absolutely, 100%, .
i also use a 2 quart filter.. got it at Autozone
Bill
Old 07-01-2008, 02:01 PM
Kent S
Kent S's Avatar
The NAPA part number is either a 1060 or 1061, one has the check valve, one doesn't. I can't remember which is which.
I don't think it matters since the filter is mounted vertically.
I use them on both of my Corvettes and my big block Chevelle.
Old 07-01-2008, 02:29 PM
roger newman
roger newman's Avatar
I would use a Baldwin B1441 if you had to take off the stock pressure relief valve when you converted to a spin on filter. The other filters listed do not have any pressure relief (B1441 relief set at 15psi).
To oil filter of choice
Old 07-01-2008, 02:58 PM
Jims66
Jims66's Avatar
FYI
http://www.knfilters.com/oilfilter.htm
Old 07-01-2008, 03:52 PM
K2
K2's Avatar
K&N is what I've used for years. Wix, Baldwin, and NAPA Gold also good choices.
Old 07-01-2008, 07:00 PM
DZAUTO
DZAUTO's Avatar
This isn't the 56 Vette, it is my 70 Chevelle which is still a Chevrolet engine. You can see how far down the (2qt) WIX 51794 filter goes here (I was replacing the clutch).
Quick Reply: oil filter of choice
