Vintage Air / Amp Draw
Old 06-08-2008, 05:34 PM
woodsdesign
woodsdesign's Avatar
Default Vintage Air / Amp Draw
Guys,
My vintage air works great but every time I run it I notice that the amp meter goes way over to the right. I upgraded to the higher output alternator. It this a concern or just the way it is. If it is a concern what can I do to fix it.
thanks
Old 06-08-2008, 07:53 PM
wombvette
wombvette's Avatar
Originally Posted by woodsdesign
Guys,
thanks
I would say, you have it wired into the circuit that the gauge is monitoring. Wire it somewhere else.
Old 06-08-2008, 07:59 PM
Kensmith
Support Corvetteforum!
Kensmith's Avatar
I also have VA and it does not affect the gauge.
Old 06-08-2008, 08:40 PM
woodsdesign
Ken,
Where do you pick up the main power from. I ran it rignt to the fuse box.
Old 06-08-2008, 08:49 PM
67-427ci
67-427ci's Avatar
Larry: You need to connect the fan to the main bus connection on the horn relay.
Roy
Old 06-09-2008, 10:15 AM
Kensmith
Kensmith's Avatar
Ken,
I believe the battery terminal on the starter. I am not running an electrical fan either.
Old 06-09-2008, 12:26 PM
1320jon
1320jon's Avatar
How well does it cool. I used one of theres in my 64 elcamino and was not real impressed with the amount of cool. With temps getting to the 120's, I want to get ac in my 64 roadster, but am concerned that it may not cool well enough to be truely comfy inside.
I run a lt1/t56 in the 64 with an electric fan, which is also what is in my ecamino.
Old 06-09-2008, 12:31 PM
Ernie67
Ernie67's Avatar
Just curious, you guys running the air with 4 speeds? Does the manual trans affect anything?
Old 06-09-2008, 01:59 PM
Loren Smith
Loren Smith's Avatar
I saw a Corvette at a show in February that had a generator and an aftermarket AC. It wasn't one of those Powermaster Powergen alternators that look like a generator, either. The owner wasn't around so I didn't get a chance to ask how it functioned.
Old 06-09-2008, 02:43 PM
Kensmith
Kensmith's Avatar
Have a TKO 600 5 speed. Don't know why it would affect the A/C?
Old 06-09-2008, 02:48 PM
Kensmith
Kensmith's Avatar
It works ok but not like the big Super Cooler VA sells. I had the Super Cooler in my 32 Ford and it would blow you away with cold air. The Corvette Sure Fit system is good but nothing like you newer daily driver. Don't get me wrong, I like my VA since it gets really hot where I live.
Old 06-09-2008, 07:18 PM
woodsdesign
Roy [/QUOTE]
Roy, Do you mean under the hood or at the fuse box? If you have a pic that would clear it up.
To Vintage Air / Amp Draw
Quick Reply: Vintage Air / Amp Draw
