I want to take the clock apart in my '62 to clean the points. How does one remove the hand setting ****? Do you hold the shaft with a needle nose pliers and unscrew the ****?
Thanks, I will give it a whirl and see if I can screw it up.
When I rebuilt mine I remember holding the stem with a small needle nose and my **** was on there pretty good ( I'm sure since new) so I actually covered the know with a small piece of cloth to protect it and used a small pliar to loosen it.
