Right side mirror?
Old 06-06-2008, 12:43 AM
KC John
KC John's Avatar
C2 of Year Finalist (appearance mods) 2019
Default Right side mirror?
I was thinking about adding a right side mirror? I'm too old and stiff (OK, actually too fat also) to turn around to see where the right side of the car is.
I have the early '63 mirror style (long base), does anyone know if I can use a left side mirror on the right side? It appears to be symmetrical, so it looks to me like it should work. That would be a welcome addition for me.
Old 06-06-2008, 02:06 AM
SPLITRAY
Support Corvetteforum!
SPLITRAY's Avatar
You can buy right and left side mirrors. I purchased a passenger side short base with bow tie emblem, but have not yet installed it.
Old 06-06-2008, 07:39 AM
6T7L71CPE
6T7L71CPE's Avatar
If you install a right one it does not need to be in the same fore/aft position as the Left one. The wing window may obstruct the view. Place it where your seating position needs it. "Ask me how I know"
BTW, These ole mirrors are flat, so the "Things May Appear Closer Than They Are" does not apply. I added a real tacky convex mirror to mine so I can see better. Someone here had a large convex cut to size and installed in place of the flat mirror. I haven't found one big enough to do that yet.
Old 06-06-2008, 07:55 AM
7vettes
7vettes's Avatar
Location: If I say it's safe to surf this beach ......then it's safe to surf this beach
You see a lot of C2's with a right-side mirror. Here's just a few I noticed while casually flipping thru some car show pics, could probably find another dozen or more. Interesting that the cars aren't necessarily customs or mods, but otherwise stock looking cars, and the pics weren't taken because of the mirrors, but because they're good looking Vettes.
In my Coupe I have one of those wide-angle rear view mirrors, as well as an aux. wide-angle mirror on the right side sun visor that gives a pretty good view of that side, but I like the idea of the extra outside mirror......
Old 06-06-2008, 09:42 AM
67vetteal
67vetteal's Avatar
Hello John, I installed the right side mirror on our coupe way back when, the 70's! I'm 6'1" x240Lbs.. The mirror is installed symetric to the left mirror and I see just fine. I highly recommend one. Al W.
Old 06-06-2008, 10:48 AM
Ironcross
Ironcross's Avatar
Default Off Topic, but Important
Originally Posted by 7vettes
Why can`t people correctly line up bumpers?....
Old 06-06-2008, 11:24 AM
7vettes
7vettes's Avatar
They're too busy adjusting their mirrors......
Old 06-06-2008, 12:47 PM
richscorvettes
richscorvettes's Avatar
St. Jude Donor '06-07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
We added a passenger side mirror to our 63 and used the early long-base style. While they do sell a right side mirror for the later mid-year style mirror I couldn't found one for the early style. However, the drivers side mirror worked perfectly on the passenger side as the early style base has the mounting screw toward the rear of the base as opposed to the side location on the later mirrors. You'll also need the inside mounting plate and rivets.
Rich
Old 06-06-2008, 01:50 PM
KC John
KC John's Avatar
Thanks Rich,
I couldn't find a right side mirror either that's why I asked this question. I knew I couldn't be the only one that wanted a right side mirror.
I just needed to know if there were any reasons I would not be able to do it.
Old 06-07-2008, 09:20 PM
babylonvette
babylonvette's Avatar
i bought a r/s mirror for the 72 coupe i drove it once and couldn;t see on r/s ,local corvette dealer had one in stockfor 50dollars, it came with rubber inserts and a template, just line up on door drill 2 holes install inserts and install mirror ,5 minutes for the whole install now i feel safe having wife drive the car,car actually looked off balance with only one mirror now it looks correct
Old 06-08-2008, 02:33 AM
oldschoolvette
oldschoolvette's Avatar
Old 06-08-2008, 01:13 PM
1955 copper
1955 copper's Avatar
2015 C1 of Year
C1 and 2 was a GM accessory from the parts department
Old 06-08-2008, 02:49 PM
JohnFromVentura
JohnFromVentura's Avatar
Where can you find a right one today?
Thanks, John
Old 06-08-2008, 04:16 PM
KC John
KC John's Avatar
Thanks, John
I'm going to just buy a left and mount it on the right.
Old 06-08-2008, 06:18 PM
Classic-Chevy-Guy
Classic-Chevy-Guy's Avatar
Do repro mirrors come with the template and do you need to take the door panel off to install?
Old 06-08-2008, 06:51 PM
KC John
KC John's Avatar
It looks like you have to buy the mirror, the backing plate and the gasket and screws separately. If they could they would try to charge you for the chrome also. Parts for Corvettes are just ridiculous.
Old 06-08-2008, 10:17 PM
Classic-Chevy-Guy
Looks like Zip Products has the entire kit. Still wondering about the template and how to install?
To Right side mirror?
Old 06-09-2008, 11:55 AM
JohnZ
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
Don't trust a template. Sit in the driver's seat and have a helper position the right side mirror so you can see it; if you locate it without a helper, you may wind up with the vent window frame in the way.
Old 06-09-2008, 01:21 PM
Classic-Chevy-Guy
John,
Do I need to remove the door panel, or can it be installed from the outside?
Old 06-09-2008, 01:32 PM
KC John
KC John's Avatar
There is a backing plate to guard against cracking the fiberglass. You can only get to that by taking off the door panel.
I never heard of Zip Products, so I'll have to look into that.
Quick Reply: Right side mirror?
