[C2] Drop base air cleaner
Would like to know what others are using for non-original drop base air cleaners. A PO butchered the original by cutting clearance holes for a Holley double pumper and many years ago I picked up an aftermarket model that while does fit, it has an embossed Holley logo that I don't like and I can only fit a 2" high filter element in it while I think others have been able to go taller. I have a Edelbrock Performer manifold which I believe many others also run on their small blocks and a newer Holley 750. I also have a insulating spacer plus heat shield that totals 1/2" under the carb.
Thanks!
Thanks!
I found this which may allow me to use a taller filter element since it's the outer front edges of the existing round cover that contacts the reinforcing ribs of the hood. Thoughts?
65air_coupe (08-28-2023)
The base that brick white posted is from a 67-69 Z/28. Or a 68-72 L-88 (You can use 67 L-88 and it doesn’t have the valve cover vent) and it is the lowest drop air cleaner out there. And it clears a double pumper without issue. Usually… I have had one that contacted the secondary accelerator pump spring, but more than 1/2 dozen more that worked perfectly.
Thanks for all the responses.
