Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-28-2008, 07:16 AM   #1
paul 74
Ontario, Canada
Support Corvetteforum!
paul 74's Avatar
Default Fuses? How Do They Differ?
This is not necessarily C2-related but it does have automotive relevance. In looking through the Owner's Manual for my latest old Corvette I had a peek at the fuse and breaker data. To my eye they all look very much the same: glass and cylindrical. But the descriptions differ. Here are examples:
-headlamp circuit, circuit breaker (seems straight-forward)
-backup lamps & turn signal, AGC fuse (20 amp)
-heater-A/C, 3AG fuse (25 amp)
-tail lamps, SFE fuse (20 amp)
What is the difference between AGC, 3AG, and SFE?
*Edit*-This pic shows the whole story. The year is 1974.
Click the image to open in full size.
paul 74 is offline   Reply With Quote
Old 04-28-2008, 08:10 AM   #2
jim lockwood
CF Senior Member
jim lockwood's Avatar
The SFE fuse for the tail lights has a slower reaction time so the surge current of 4 brake light filaments coming on won't cause it to open up. One manufacturer of the era had trade name of "Slo-Blo" for this type of fuse. These were available by special order through Radio Shack a few years ago.
AGC vs 3AG, I couldn't say.
Jim
jim lockwood is offline   Reply With Quote
Old 04-28-2008, 06:49 PM   #3
JohnZ
CF Senior Member
AGC glass fuses are all the same length (1-1/4"), regardless of rating, from 1 amp to 30 amps. SFE (Society of Fuse Engineers) glass fuses are the same diameter as AGC fuses (1/4"), but are six different lengths depending on their amp rating (from 5/8" long for 1-amp to 1-7/16" long for 30-amp).
JohnZ is offline   Reply With Quote
Old 04-28-2008, 06:56 PM   #4
Bill Irwin
CF Senior Member
Society of Fuse Engineers? Who would of thunk? Bill.
Bill Irwin is offline   Reply With Quote
Old 04-28-2008, 07:19 PM   #5
paul 74
Ontario, Canada
paul 74's Avatar
Thnks but why would an SFE 20-amp and an AGC 20-amp be included in the same fuse box?
Old 04-29-2008, 08:08 AM   #6
jim lockwood
CF Senior Member
Brain spasm with my posting yesterday.
The SFE fuse designation is NOT a slow acting fuse. I believe the original automotive designation for a slow acting fuse, as is needed for brake lights, was SAE.
In any event slow acting fuses are available in the Bussman brand, the MDL series:
http://host1.publiquik.com/bussmann_...?familyUid=695
Jim
Old 04-29-2008, 03:20 PM   #7
mikem350
CF Senior Member
Don't stress over this, just use the correct amp rated fuse!
The "slo blow" refers to the time it takes to blow when the fuse is in a severe overload condition.
mikem350 is offline   Reply With Quote
Old 04-29-2008, 04:13 PM   #8
paul 74
Ontario, Canada
paul 74's Avatar
I've come to that conclusion .
Old 04-30-2008, 10:44 AM   #9
magicv8
9 Hot Rod Power Tours
magicv8's Avatar
SFE fuses are 'automotive', rated only to interrupt 32 volts. The length depends on their current rating, ranging from 5/8" for a SFE-4, to 1-7/16" for a SFE-30. AGC fuses are 'general purpose', they are always 1/4" by 1-1/4", available in 250V ratings to 10 amps, & 32V ratings to 30 amps. An AGC-20 is the same length, & pretty much interchanges with an SFE-20. Both types are "fast acting", but according to Buss charts, the SFE is a little faster. An AGC-20 is rated to carry 27 amps for up to 60 minutes, while an SFE-20 will blow in under 2 minutes. However, the 60 minutes is given as a maximum, while the 2 minutes is apparently typical, so that may not be an accurate comparison.
The 3AG fuse is "fast" acting. Typical times at percent of rated current are: 4 hours at 110%, 1 hour at 135%, 5 seconds at 200% - all at 32 volts.
ACG fuses have about the same time@load ratings, but are rated at 110volts.
Which is specified should depend on several factors: whether ambient temperature of the device will effect the current draw, start up draw interaction if multiple devices are on the same fuse, and of course the preference of the designer.
magicv8 is offline   Reply With Quote
Old 04-06-2013, 09:03 PM   #10
cor66vette
CF Senior Member
cor66vette's Avatar
Old thread yep! But this is good reading ... especially for someone like me who just went through the gamut with the fuse panel.
cor66vette is offline   Reply With Quote
Reload this Page Fuses? How Do They Differ?
Tags
3ag, acg, afe, agc, beteween, corvette, difference, fuse, fuses, glass, mdl, sfe, types, what, whats
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Sanity check for seat heaters run off a relay Smokin Joe Audio/Electronics 3 06-21-2014 01:29 AM
1972 LS5 fuse panel question MndShp C3 Tech/Performance 1 11-08-2013 10:35 AM
New tires for my C6 Z06 (355/25/19) PUNISHER Z06 C6 Corvette General Discussion 13 07-30-2013 12:24 AM
1977 C3-Power Windows/guages don't work--electrical advice needed Jackogr C3 General 9 03-14-2013 04:15 PM
Circuit Breaker to Replace 20 Amp Brake Light Fuse Sxrxrnr C1 & C2 Corvettes 9 11-21-2012 01:24 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
