Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-25-2008, 07:07 PM   #1
Stingxray
CF Senior Member
Stingxray's Avatar
Default Functional 63 Hood vents?
Don't laugh ........ But has anyone seen .......or made 63 hood vents functional? I was thinking a fabricator with a mill could louver out a billet 1/2 plate aluminum to match the "fake baker tins. And naturaly cut out the fiberglass portion of the hood. The Idea is sound for two reasons. Exhaust heat from the radiator and reduce front end lift at high speeds. Some molding of the hood frame on the back side would be needed also. Think it would it look hokie? Any Ideas are appreciated.
Stingxray is offline   Reply With Quote
Old 03-25-2008, 07:47 PM   #2
wmf62
CF Senior Member
St. Jude Donor '07
Support Corvetteforum!
wmf62's Avatar
don't park it outside in the rain...
Bill
wmf62 is offline   Reply With Quote
Old 03-25-2008, 07:51 PM   #3
magicv8
9 Hot Rod Power Tours
magicv8's Avatar
Overbudget beat you to it.
Click the image to open in full size.
magicv8 is offline   Reply With Quote
Old 03-25-2008, 08:28 PM   #4
wmf62
CF Senior Member
St. Jude Donor '07
wmf62's Avatar
Quote:
not really, that's a diamond pattern; not the rectangular one of the original..
Bill
Old 03-25-2008, 09:05 PM   #5
jim lockwood
CF Senior Member
jim lockwood's Avatar
Quote:
Your thinking makes plenty of sense and functional vents made from billet would look awesome.
But will you be driving with the floor vents open?
If so, the negative pressure at the cowl vents will induct the exhausted engine heat, sending it into the passenger compartment. This is one of the reasons GM didn't make the vents functional.
Jim
jim lockwood is offline   Reply With Quote
Old 03-25-2008, 09:05 PM   #6
BADBIRDCAGE
CF Senior Member
Send a message via AIM to BADBIRDCAGE
I can dig it as long as it doesn't end up like this.
Rich
BADBIRDCAGE is offline   Reply With Quote
Old 03-25-2008, 09:08 PM   #7
Trophy Blue
CF Senior Member
Trophy Blue's Avatar
Quote:
Rich
My eyes are bleeding!
Trophy Blue is offline   Reply With Quote
Old 03-25-2008, 09:13 PM   #8
nassau66427
CF Senior Member
nassau66427's Avatar
Location: going faster miles an hour...with the radio on in browns mills new jersey
You'd probably accomplish more by opening the side vents and adding a chin spoiler.
nassau66427 is offline   Reply With Quote
Old 03-26-2008, 09:28 AM   #9
silverslashstreak
CF Senior Member
silverslashstreak's Avatar
Jim is right on, the hood vents were originally designed to be functional, but after testing they found the engine heat all ended up inside the cabin through they cowl vents. So at the last minute they closed them up and made them fake.
I think you already have the best plan for getting under hood heat out of 63 and 64s. Very taste full and functional at the same time.
silverslashstreak is offline   Reply With Quote
Old 03-26-2008, 09:34 AM   #10
silverslashstreak
CF Senior Member
Sorry Stingxray, I just looked at your avatar closer, I thought you were the fellow forum member that opened up the side vents and put the spears in place to hide the openings to let the heat out. Someone here will probably post pictures of his car.
Jeff
Old 03-26-2008, 12:17 PM   #11
toddalin
CF Senior Member
Quote:
Jeff
Voila!
One day maybe I'll get around to putting blacked-out screens on the inside of the cut-outs.
And while we were at it..., we also opened the hood, but retained the chrome trim.
toddalin is offline   Reply With Quote
Old 03-26-2008, 12:35 PM   #12
magicv8
magicv8's Avatar
Don't laugh ........ But has anyone seen .......or made 63 hood vents functional? The Idea is sound for two reasons. Exhaust heat from the radiator and reduce front end lift at high speeds.
Have you removed the big steel sheet metal splash guards that blocks the underhood air from exiting behind the exhaust manifold outlets? That helped my A-C condenser through the radiator airflow a lot.
Old 03-26-2008, 01:02 PM   #13
sub006
CF Senior Member
Even if you keep your vents closed, you'll probably get an oily film on the windshield. Non-smogged small blocks tend to exhale underhood at high RPMs.
sub006 is offline   Reply With Quote
Old 03-26-2008, 02:03 PM   #14
Vettebuyer5869
Moderator
Vettebuyer5869's Avatar
Don't laugh ........ But has anyone seen .......or made 63 hood vents functional? Think it would it look hokie?
Hokey? Naw. Just... nasty.
Vettebuyer5869 is offline   Reply With Quote
Old 03-26-2008, 02:13 PM   #15
needforspeed150
CF Senior Member
I have thought about doing just that. Do what you are talking about and have a sheet metal shop do you a pan to glue to the underside of the hood to let the water run to either side. I thought about water exit going to the front but that doesnt work going down the road in the rain.
Let us know if you do it.
needforspeed150 is offline   Reply With Quote
Old 03-26-2008, 06:44 PM   #16
Stingxray
CF Senior Member
Stingxray's Avatar
Default Hood Tin's
Great feed back everyone...... It's Like an old British friend use to say.....( British accent) "If it's not factory............ it's Not RIGHT. There are reasons FOR and Against. The SWC is already painted and would hate to mar it up. The interior Heat, Oil spatter & rain water issues are all things I wanted to hear before I got out the SAWSALL! The Pie tins look good for now till I get the car back on the road. Thanks for Stories & Lifes Lessons
Reload this Page Functional 63 Hood vents?
Tags
63, corvette, hood, vents
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
