NEW Big Block in the old vert
Just got my engine in and running..still a work in progress..had to modify the hood..I know that some purist will not like it but had to keep the rain out somehow..
http://i131.photobucket.com/albums/p...Picture006.jpg
http://i131.photobucket.com/albums/p...Picture001.jpg
http://i131.photobucket.com/albums/p...cture002-1.jpg
Well, it is your car....
Sweet looking motor....specs?
468 CID 4 bolt forged and balance bottom end with some pop up pistons.. we took 20 of the deck and with the small chamber heads it has some decent cylinder pressure..it has a 600 lift hydraulic cam with roller rockers and about 240 degrees of duration at 50..has a very nasty idle. motor should pull hard to about 6500 rpm.. the goal was to be quicker that a new C6. I have about 40 miles on the motor..once its broken in I will hook the NOS up. I have a 150 shot for the top end.
I was so tired of the "hey nice car" followed by the "owe...small block" besides the car is coded big block
I couldn't really see it well, but are you using rubber hose from the fuel pump to the carb?
While many will undoubtedly disagree, IMHO a metal line on the pressure side of the fuel pump (as originally equipped by Chevrolet) greatly reduces the risk of fire.
- Pat
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,358 Likes
There are a group of suffixes that were attached to the build sheet info for the car and contained the info that was not included on the ID tag. So based on the build sheet that came with the car...I say its coded big block......Build sheet shows the VIN and the 427 Suffix..Thats what lead me to this conclusion
Received 1,859 Likes
I have two air cleaners..... for my car. When I want to run the hillborn scoop... I just take the hood off. Got it down to about 4-minutes!
Sometimes it's just fun to break out of the mold! Your car is awesome!!!
