How fast do you drive in parades ??
C2 of Year Finalist (track prepared) 2019
2017 C2 of the Year Finalist
I usually top out at about 3 mph, and hit .04 G swerving around horse apples......
or is that too reckless ??
And I only use the 87 Vette with an auto trans. Tried it ONCE with the 62, and even with a combined first/rear gear of 11:1 running at 1K rpm idle, I had to either slip the clutch constantly or do the in/out clutch jerking along (or risk running over the above named marchers).
Note that in parades down here, there are the candy throwers (from vehicles). Last Xmas, a kid was killed by one of the parade vehicles. I would not make any sudden moves in those circumstances, and keep a wary eye for the kids.
Plasticman
I did at one time drive my cars in parades but not any more. All my corvettes are 4 spd and it is to hard on the clutch and my leg to do that kind of stuff. Also I could not get enough air to the car and the temp would climb so Parades are out for me. But your speed sounds about right.
I did a parade once in my '65 - never again! My leg was exhausted by the end and I think I killed at least half the life of my clutch.
The '78 is an auto trans so I'd do a parade in that, but never with a manual trans again.
I drove the '65 4-speed with 3:08 rear differential in a loonnnggg Christmas parade in West Memphis, Arkansas several years ago. Never again, I vowed, and never have. Since then, I use the '66 convertible with Powerglide, such a dream!! The convertible is more of a parade car anyhow, a lot more popular with the homecoming queens.
The parades I've been in for the past several years have learned that the saddle horses and horse drawn wagons go in the rear!! Don't know why it took folks so long to recognize this, I believe the high school bands were more of an impetus for change here than the cars were, though.
you guys need more gear !!
I run a close ratio box and a 4.56 to keep the speed down in first gear.......
heck, at 600 rpm in first. I chug along at a 3.4 mph, while you speed demon maniacs with your 'highway' gears and 'wide ratio' transmissions chase defenseless Cub Scouts at a neck breaking 5.2 mph........
If I know I will be following the Shriners, I pull out the 5.13 and back it down to a respectable 3.06
heck, at 600 rpm in first. I chug along at a 3.4 mph, while you speed demon maniacs with your 'highway' gears and 'wide ratio' transmissions chase defenseless Cub Scouts at a neck breaking 5.2 mph............ [/I]
for the record, I believe us "Wide Ratio" guys with 4.11 "have more gear" than you do in 1st ....... right?
PS: when you going to come get your hood
you are correct, though, about the tranmission, and in the name of saftey I will get that swapped out at once.......
Similar to a long parade though is the Woodward Avenue Dream Cruise in Detroit, although you can occasionally drive faster than parade speed through certain sections of the route. An amazing experience and great way to spend the best part of a week. My left leg was sore for a week, from all the stop and go clutching. - Pat
The only parade I've ever done was at the invitational of Corvettes at Carlisle. Even at this relatively short event, there sure were a lot of boiling rads!
Cruz
1 Post
Carried one Queen once in the 62, that was enough. Now in Mardi Gras parades I drive the 1956 SEAGRAVE pumper truck. Nice smooth super low gears behind the V-12 dual ignition engine. Pull the throttle out a tad drop her in first and parade on!!
Drove the '62 in a Memorial Day Parade in Carnegie, Pa. years ago; LONG "uphill" behind a (slow) marching band...LOTTA "clutch-slippin' " like mentioned above Swore: "never again"
Then - in '06 - was one of 5 GM/Chevrolet-manufactured 'verts invited to participate in the Pittsburgh Steelers Super Bowl Victory Parade
Couldn't "pass" on THAT What a RUSH! 1/4 million spectators honoring/cheering the Steelers It was fairly level "dahn-tahn" but I wouldn't have noticed any discomfort at all...I was too PUMPED!
Live Free or Die
I go as fast as I can using the other cars and band members like slalom cones. The big tuba guys are kinda hard to get around but the baton twirlers make for pretty easy gates. Fastest I've gotten her up to was about 150 during the 4th of July parade. I was doing drifting laps around the the whole parade as it moved. The parade was a little over a mile long so it had some sweet straightaways.
The secret to saving the clutch is to just keep the tires spinning....
Guys we have gone over all this before.
This is why you have the car. Enjoy it. Time to relive those High School days except this time the cheerleader is in your car with two more sitting behind you on the convertible hatch.
I'd much rather do this than sit in a lawn chair for the whole weekend listening too. "When I was 21, I had a Covette, but it was a 409"
I haven't driven in a parade for some time.
http://www.geocities.com/cd_mvca/jv78.htm
But I did have my '68 up to 1.50 a few times but it isn't a C1 or C2.
My '66 I had over 1.85 and maybe 1.90 if everything was correct.
The question that was originally asked is answered at this link:
http://www......showthread.php?t=10355
