Flaming River Front End Components
I'm updating a 67 Pro Street roadster that will have a 555 Aluminum Brodix motor (ala ZL1) that should be approximately the weight of a SBC iron motor. I'm looking at installing Flaming River's rack and pinion set-up, a tilt column, and perhaps one of their steering wheels.
Anyone have any experience with these aftermarket R&P syatems?
The F/R uses the stock tie rod ends so bump steer and Ackerman problems should not occur.
Should I buy the power steering version given this aluminum motor or will manual suffice?
I appreciate any opinions or experiences--
Thanks-Dandy Don
Thanks-Dandy Don
AFTERMARKET RACK and PINION STEERING?
Thanks-Dandy Don
Thanks-Dandy Don
Thanks-Dandy Don
Thanks-Dandy Don
Thanks-Dandy Don
I have a ZL-1 in my '65. Fortunately it has factory PS which works great (had Guldstrand rebuild box once upon a time) Fellow club member/mechanic installed a Steeroids unit on a small block 64; didn't exactly drop on. Needed substantial drive & adjust. Seems like there
would be a lot less room to bend the double universal joint connection
around a big block.
