1963 Corvette Inner door knob question
1963 Corvette Inner door **** question
Hello
I noticed the inside **** (black plastic ball) on the passenger side is loose. I first thought that the **** needed to be tighten (screwed) but it is tight on post. The post that goes into the mechanism (latch appears to be "X" shape with a smal spring in center) is loose. I have never taken off the door panel before on this car. My question, is there a screw on the back of the post that can be tighten, or is the post riveted to the latch?
Pete
Pete
I think you'll find that most of them are loose. I don't think it can be tightened. I put a piece of foam behind mine so when the door panel is on it makes it a tighter fit.
I have an old old article that has a cure for your problem. If you want I can search my archives [boxes of vette mags] and fax it to you. Chuck is right on, the article will provide the details. BTW the return spring is available and should be replaced also.
brgds
rene
brgds
rene
brgds
rene
brgds
rene
This thread covers more of the latch possible issues (Less frequently will happen to passenger door) http://forums.corvetteforum.com/show....php?t=1718762
Good Luck,
Andy
On a '63 the door chrome ball is supposed to be black? Next you'll tell me the Stick shift ball is supposed to be black too! At least my console plate is black.
