Headlight door switch
Old 06-15-2017, 05:29 PM
macs65
macs65's Avatar
Default Headlight door switch
The switch in my 65 must be pushed forward to open the doors and pulled back to close. Seems like it should be the other way round???
If mine is wrong would it just be a matter of swapping the wires on the switch??
Old 06-15-2017, 08:58 PM
buns
buns's Avatar
The headlight door switch connector is riveted together, so no easy way to reverse the wires there. Only solution is to remove the connectors at the headlight motors, unpin the terminals and reverse them. Probably not an easy job with the hood on. (Just guessing).
Old 06-16-2017, 07:15 AM
macs65
macs65's Avatar
Thanks buns, it works fine the way it is, guess I'll leave it alone for now.
To Headlight door switch
Quick Reply: Headlight door switch
