C1 tank with built-in elec fuel pump & return line
#41
If you throw a lit match into a recently opened can (small opening, not a coffee can) or tank of gas that has liquid gas in it, the match will go out. At least that is what the equations tell us.
But abolutely yes, you want the return line below the liquid level to eliminate static buildup.
Doug
#42
Dave
thanks for the info & the pix.... it is really helpful
i called Rock Valley this morning and they said they would supply and modify a new OEM style tank for me and install an in-tank pump and return for about what you have invested in yours. assuming that i do the EFI thing, i'll probably go this route rather than trying to reinvent the wheel...
again thanks...
Bill
again thanks...
Bill
Did Rock Valley mention anything about a baffle surrounding or sump for the pump? Just curious if there is any effort made to keep the pump from sucking air on a corner when low on fuel...
Stan..
#43
St. Jude Donor '07
they said they weld a sleeve into the tank that has a square opening on the front to make sure that fuel gets in under acceleration and that has 'spiral' openings on the sides to act as baffling (baffles me too.. ), and that the sleeve effectively has a sump in the bottom. and, as i remember, the last C1 tanks are supposed to have internal baffles to control fuel slosh in cornering, but i don't know that as a fact.
the fuel pump module and return line then go into the sleeve.
Bill
#44
Hmm..Well that may be the ticket. Looks like the tight fitting issues of a stainless tank would be eliminated and and a considerable savings too. Stainless tanks are real nice...but stock tanks last 40-50 years, so maybe that will be long enough. If not... shucks, you just may just have to buy another one.....heh heh!
The number was about $700 correct? Is that soup to nuts... eveything needed.
Stan..
Stan..
#45
St. Jude Donor '07
Stan..
Stan..
Bill
#46
Fuel pump
Bill, as mentioned earlier the "Tanks" setup is pretty neat. I used in in a 40 Ford that I built with TPI and I have put their pump in my stock 62 tank that I installed the LS1 in. All you have to do is cut the hole and mount the pump inside the tank, it has a baffle setup in it and has a return line also that returns the fuel to the bottom of the tank. The picture posted earlier looks just like mine, you get everything you need.
Good luck,
Wade
Good luck,
Wade
#47
St. Jude Donor '07
Wade
i just went back and looked at Misfit1's pix and between the 2 of you figured out what he was really saying... i didn't realize that there was a company called 'Tanks'; just Googled it and finally found it. i wouldn't be surprised if that is the unit the Rock Valley uses in their tanks. i'll give them a call..; but it may be easier (for me) just to get the whole thing preassembled; i'll ask if they can do that.
haven't heard from you in a long while, how'd your projects turn out?
Bill
Bill
#49
Hey Bill,
I guess that was a little difficult to understand. Yes, the company is called
Tanks http://www.tanksinc.com/
and I got the high performance pump, PA-4.
The kit came with everything to drop the pump into the tank. There in no way to mount the pump so their baffle will sit flat on the bottom of the gas tank. (Yes, their pump comes with a baffle.) So, I did some creative cutting on the pump mount and angled the baffle so it slightly hovered down the slope of the gas tank and the pump sat at the bottom of the gas tank angle. The money spent, I’m guessing at around $700, was for the entire fuel setup from gas tank to fuel rail not just the gas tank
If I had to do over again, I would still go with the GM filter/regulator. That is a very clean, efficient, single line run to your injection unit.
Hell Bill, I’ll set up your tank for a lot less and install the high performance Tanks pump!.
#50
Hey Doug, I used to own a gas station and on two occasions I witnessed this. Some guy fills a plastic gas can in the back of a pickup truck with a plastic bed liner and the combination seams to set off a static charge and in turn, starts a fire. The second one I got on the intercom to warn the guy when, Puff, it caught on fire. I think the man soiled himself ! They didn’t explode, but they did catch fire, close enough for a disastrous outcome. I guess in theory it happens the way you explained (way over my head), but ya know, anything can happen!
#52
Doug
#53
62 Corvette
Bill, I have stalled with my restomod Corvette. I mocked up everything then removed it and took it to the paint shop back in the fall. My painter is very busy and I think maybe dragging his feet also. Maybe I will have it back in a few months and put everything back in.
I am almost at the point of maybe selling it, maybe let someone else paint it and put the interior in it. It does look sweet with the powder coated chassis and the LS1 engine and 4L60E trans painted the same color as the chassic, it will make an awesome car.
Thanks and good luck on your FI,
Wade
Wade
