has anyone installed interlocking tiles in garage?
I was looking @ another forum and this members garage floor was just completed using the interlockable tiles from costco. I thought the floor looked great and was wondering if any of you had done the same thing and if you have some pictures...pros and cons? it looks as though I could take them up if I sell the house and move to the next one without issue. Costco has a sale going on where each box is quite a bit less than normal.
thoughts?
thoughts?
A bunch of folks on the C6 forum have done it.
I plan to do it to my "daily use" garage, and if it holds up well I'll be doing it to my workshop, where I build my cars, as well.
I used the Kiwi tiles before but probably wouldn't again. Despite the mfg's claims, they would dent from the floor jack and jack stands. They stained from an ATF spill. If you stop or start quickly the tiles may bunch up some. The non-skid ribs were effective but they also made cleaning more difficult as you had to hand wipe next to each rib.
http://www.costco.com/Browse/Product...lang=en-US&s=1
here is the floor I was looking at...any experience with this?
I put in down in July 2001 (it was call MOTORMAT then) and it has held up OK not GREAT but OK. If you use it normaly for parking and routine maint you will love it but when you start doing major things that require lots of jacking and or dragging parts it will scar, not destroy but have scratchs. It gets dirty like all flooring but cleans up nice.
And YES I would do it again because it is better to lay on the oily concrete.
Here is my install ===>> Garage Redo
How is looked in July 2001 when installed.
I chose a "ribbed" material made by swisstrax - it has been down now for over a year and the only cleaning I've needed to do is vacuum leaves, etc with a shop vac. It does not show any footprints or tire tracks - highly recommend it!! Cost was about $3.50 psf installed. The material was developed initially in Switzerland, is now being molded in US.
Bob
Bob
2019 Corvette of the Year Winner
St. Jude Donor '15
For those of us who are budget-challenged, I will use this WalMart product come April in my one-car garage. The 1967 nests in there during the summer period. I have tried concrete paint, epoxy, whatever and nothing holds up with Canada's salty winter. Perhaps this rubber overlay will. Can't hurt too bad for $225.
This commercial two-part epoxy lasted about two months.
I used a similar product in my workshop at my last home.
As mentioned, the raised bumps are a pain to keep clean. Had to wipe and scrub by hand, and they stained from various automotive and household liquids. Even some 7UP from pop cans that ruptured due to "old age" stained it!
At the new home, I went with time tested commercial floor tile in the workshop, and epoxy painted floor in the garage. So far the epoxy paint has held up great (year and a half), except for where I dropped something hard and chipped the concrete, and where I forgot to protect it from weld splatter (made a 4' x 4' protector board of masonite and cheap tile that I lay down anytime I am welding now).
Plasticman
Plasticman
A 10 * 20 area out in the open would only take 15-20 minutes.
George
And yep, we are metric as well. The Impala sitting in that garage right now has *some* klics on it: read ~637 miles.
They dent from jack stands and if you are using a floor jack you need to put a piece of wood (I use 3/4 plywood) under the jack or the wheels won't roll under the weight of the load. They will sink into the tile.
You can't keep them clean. I would not do it again.
Rich
I used race deck tiles and had similar experience. I used yellow and white. Good for illumination. GREAT feeling when you are working on them. If you have any kind of spill that makes the seams you can't get all the material up and it will wick up from the bottom and attract dirt.
Rich
Rich
Rich,
I was just kidding. Those tiled floors look great. I was pretty disappointed with the epoxy job that was done by a local company last spring. I let it be for more than a week but the first time I parked a car on it the paint lifted. And now the salt is chewing it up further.
The WalMart rubber tiles (need I say Made in China) were a Christmas gift from the Wife. I'll give them a try when the winter turns to spring and before the Corvette comes home from storage.
