Power of manual disc brakes
I am converting my 63 to disk brakes. I am using 67 parts (no kit). I am not sure I need or want power brakes on it. Won't it stop easily without power?
It is a four speed with no power steering.
What do you guys think?
Plasticman
I'm sure others will chime in, but I enjoyed my '71 4-speed without power brakes or steering. It was my summer daily driver and while I did not race it, the brakes felt firm and responsive (including a trip through the mountains).
I still have my '66 Chevelle without power brakes (all drums) or steering. Given similar tires, the Corvette felt MUCH better braking (and pretty much everything else). I understand this isn't a fair comparison, but these two cars are my only reference points to offer.
I think Plasticman's experience with the frozen booster isn't quite representative of a manual system. I've driven power brake systems with vacuum source failures and they did not feel the same as manual brakes.
- Brad
- Brad
Received 1,844 Likes
I have a '63 with manual drums. I have a '65 with manual disc. I do not guarantee either is representative of other '63's and ' 65's. That said, the '65 requires slightly less pedal pressure than the '63 for equal braking. Not much difference. I'd say if your current drum brake pedal pressure didn't offend you, the manual disc brakes won't either. They both bother some people. Make sure you get the correct diameter master cylinder with the manual brakes or you could end up with a hard pedal. I believe you need a 1" cylinder.
I have a 65 with 4 wheel disc brakes. I went to the power with dual master cylinder. Best thing I have done to the car. Feels soooo much safer with all the crazy people cutting me off or hitting their brakes. I am feel comfortable instead of keeping way back just in case! Love them!
The only problem with that is, you get the brakes working that good, now somebody will bust you in the butt for stopping too quick.
Did the same thing to my '65 (with 4-wheel discs of course) exactly one year ago. I have been driving the car since 1971 and would never go back; I have soooo much more confidence in traffic.
Maybe I am old and weak, but the brake upgrade was so successful that I will now add power steering and aftermarket AC. Then maybe power windows.
Please, somebody stop me!
St. Jude Donor '07
Having daily driven a 66 w/out power brakes, and then a 70 Vette with power, I would say I am confused. My 66 never needed the power brakes, but my 70 needed them badly (drove it in very cold weather when the power booster would freeze up - and braking then was terrible!). But then again, the 70 coupe was a loaded vehicle (every possible option), and the extra wgt. may of been the difference. The 66 convertible had one power option - the power antenna!
Plasticman
Plasticman
I did the whole shot to my 65 coupe. Added power brakes, steering and Vintage Air a/c. It makes the car a lot more fun. This winter I am upgrading to urthane bushings, KYB shocks and i think a fiberglass spring. I also ordered a 65 BB hood.
The power brakes were part of my rebuild. I remember a member saying that the power brake additive would stop on a dime and give you 9 cents change. He is almost right, it's closer to 10 cents change. I have made a couple of quick stops, it's almost to much. I love it.
Dennis
Dennis
I have a 65 with the DRUM brakes and added the power brake booster and it made a HUGE difference. We did the same to my dads 65 DRUM brake car. I also have a 66 Chevy II SS that has disc in front and drums in the back and it doesn't have PB and its kinda scary, I just ordered a PB booster so I can't wait to get it.
Just remember, stopping power will ultimately be controlled by tire adhesion to the road, not my the brakes.
I have enjoyed the opinions shared and I have heard before how much owners enjoy adding power assist to their brakes. That being said does anyone think that their power assist will enable them to stop in a shorter distance or just with less effort (or the time taken to exert proper pressure)
For me a reason given to stop or slow down has always been enough encouragement for me to exert the proper amount of pressure as quickly as necessary and I question whether a power assist would shorten the distance any.
BTW does a dual manual system require more pedal effort than a single master cylinder?....... for safety sake that is a change I am thinking of doing this winter
Blessings
Doug
I don't have power steering nor power brakes on my 65 coupe. I really don't see the need for either. I have to parallell park it quite often, with no problems. As for the brakes, they do stop without a lot of excessive pressure.
