Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-13-2007, 06:27 PM   #1
investigator759
CF Senior Member
investigator759's Avatar
Default Should I use teflon tape on fuel fittings ??
I am installing a new fuel filter in my Vette, should I use teflon tape on the fuel fittings ??
investigator759 is offline   Reply With Quote
Old 10-13-2007, 06:33 PM   #2
MikeM
CF Senior Member
Quote:
Not only should you not do it. Don't do it. If you're not careful, it can get in the fuel line and cause problems with your carb needle/seat and jets.
MikeM is offline   Reply With Quote
Old 10-13-2007, 06:37 PM   #3
Trophy Blue
CF Senior Member
Trophy Blue's Avatar
Quote:
I was always told not to use teflon tape because, of that reason.
Trophy Blue is offline   Reply With Quote
Old 10-13-2007, 07:57 PM   #4
Jalopy31
CF Senior Member
Jalopy31's Avatar
Default Thread sealer
I agree with the others that do not recomment teflon tape. If you feel the need to seal the threads, you may want to try a liquid thread sealer (not a thread locker) made for this type of application.
I used it on the fittings when I set up the 3x2 system on my hot rod, and it worked fine. Follow the instructions closely by not putting the sealer on the first few threads to prevent it from getting into the system. This product does not harden fully, thus providing a good seal.
I bought mine at NAPA - I believe it was a Permatex product.
Jalopy31 is offline   Reply With Quote
Old 10-13-2007, 08:28 PM   #5
Plasticman
CF Senior Member
Plasticman's Avatar
Send a message via ICQ to Plasticman Send a message via AIM to Plasticman
Just to clarify, teflon tape does not belong on automotive application threads - period (as noted above).
If the threads are pipe threads (interferance type tapered threads), then used a teflon pipe thread sealant (which is a thick paste).
If the threads are typical fuel system flare fittings, do not use any sealant on the threads. The threads do not do the sealing - only the flared tubing does any sealing (to the opposing flare on the mating fitting), and should not need any sealant. It is acceptable to put a very, very small amount of anti-seize compound on the threads (for ease of assembly and disassembly later on).
Save the teflon tape for your house water pipes.
Plasticman
Plasticman is offline   Reply With Quote
Old 10-14-2007, 12:16 AM   #6
wmf62
CF Senior Member
St. Jude Donor '07
Support Corvetteforum!
wmf62's Avatar
contrary to everyone else's advice, i use it...(and have never had a problem; but i agree that if it isn't properly applied, it can get in places it shouldn't... )
Bill
wmf62 is offline   Reply With Quote
Old 10-14-2007, 06:35 AM   #7
66BlkBB
CF Senior Member
St. Jude Donor '13
66BlkBB's Avatar
"Just to clarify, teflon tape does not belong on automotive application threads - period (as noted above). "
Contrare!!!! One application. Petcock on the radiator. It works great!!!!!!!
Steve
66BlkBB is offline   Reply With Quote
Old 10-14-2007, 09:58 AM   #8
Shurshot
CF Senior Member
NPT fuel line fittings require a thread assembly sealant.
AN flare fuel line fittings do not require anything but an anti-seize lube properly applied is nice to have.
Doug
Shurshot is offline   Reply With Quote
Old 10-14-2007, 10:13 AM   #9
Plasticman
CF Senior Member
Plasticman's Avatar
Doug
The biggest issue with using teflon tape is in removal and reassembly. Once the fitting has been assembled, portions of that tape will become shreaded. Upon removal of that fitting more will become shreaded, and it is the removal of these shreads of teflon tape that are the root of the problem. Most guys do not take the time to clean out all of the teflon shreads properly (especially in the female portion of the threads). Then the fitting gets reinstalled, and these loose teflon shreads can become pushed into the tube/fitting where they will become a potential blockage (even in a cooling system).
Why use teflon tape, where it can cause a potential issue down the road, when there are better products that both seal and lubricate better?
Plasticman
Reload this Page Should I use teflon tape on fuel fittings ??
Tags
applications, automotive, c2, carb, carburetor, corvette, filter, fitting, fittings, fuel, installing, line, lines, tape, teflon
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
SH*#$Y Demon carb VETDRMS C3 Tech/Performance 23 04-18-2005 02:06 PM
Fuel Pump 101 zymurgist C3 Tech/Performance 13 07-09-2003 11:10 AM
New fuel line - Check it out. dman535 C3 Tech/Performance 9 05-19-2003 01:37 AM
Use teflon tape on Jughead C3 Tech/Performance 9 04-28-2003 02:49 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
