1963 Coupe with A/C, correct Air Cleaner
Old 11-13-2007, 08:41 PM
Tonytz06
Tonytz06's Avatar
Default 1963 Coupe with A/C, correct Air Cleaner
What is the correct air cleaner for a 1963 Coupe, 300hp with air conditioning?
Thank you
Old 11-14-2007, 07:51 AM
ratmotortom
Platinum Supporting Dealership
ratmotortom's Avatar
AC cars used the "dual snorkel" air cleaner with chrome plated lid. The air conditioned air cleaner is unique as it has two locating areas that align with the carb to turn the base slightly to the right about 5 degrees.
Old 11-14-2007, 01:18 PM
Mark_Milner
Mark_Milner's Avatar
The correct air cleaner for the '63 with AC was a dual snorkel with the vent tube in front and two sections inside the hole to position the air cleaner slightly to the side to have the snorkels clear the belts and hoses.
There is some question as to how many were really equipped that way. It may be the early ones didn't get them, or that they ran out and late ones didn't. There doesn't seem to be good data on real original unchanged cars today.
The '64 and '65 AC air cleaners are different, in they have the rear vent tube.
Old 11-14-2007, 05:42 PM
Tonytz06
Tonytz06's Avatar
OK, thank you for the information. I see in the books they show the twin snorkels then say ecpt. A/C. Now it's clear.
Thanks again
To 1963 Coupe with A/C, correct Air Cleaner
Quick Reply: 1963 Coupe with A/C, correct Air Cleaner
