Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-03-2007, 02:22 PM   #1
Vet65te
CF Senior Member
Vet65te's Avatar
Default Dash Bulb Candlepower Chart?
With my '66 Coupe's dash cluster out I started replacing the various bulbs and found that someone before me had replaced the stock #1816 illumination bulbs with #1893s. One reference showed the candlepower to be the same for both while another showed the #1893s to be only 2 candlepower and the #1816s to be 3 candlepower. Also, one source did indicate the #1893s had greater longevity. I definitely don't want to reduce the illumination of the gauges but if they are equally bright it seems I might consider the longer lasting bulbs. I also saw that later year Corvettes, like 1969, went to #1895 bulbs.
Is there a link to a chart showing the various automotive bulbs and their specs? Thanks
Vet65te is offline   Reply With Quote
Old 06-03-2007, 02:49 PM   #2
Plasticman
CF Senior Member
Plasticman's Avatar
Send a message via ICQ to Plasticman Send a message via AIM to Plasticman
You are correct that 1816's are rated @ 3 mscd, while the 1893 is rated @ 2 mscd. Also, the 1816 gets it's rating at 13 volts, while the 1893 is @ 14 (which means for the same voltage, the 1893 will be weaker still). Both of these bulbs are rated @ .33amp. The 1816 is rated for 1000 hours, while the 1893 is for 2500.
Click on the following link, then to "Miniature Incandescent Lamps", and then go to T-3-1/4:
http://www.sylvania.com/ConsumerProd...ting/ECatalog/
You might be able to use the G-4-1/2 #6253 (if the globe will fit), which is rated at 4.2 mscd @ 12 volts, but only has a 200 hour life @ 12 volts, and would be even less at a normal vehicle voltage of 13.5+ volts.
Plasticman
Plasticman is offline   Reply With Quote
Old 06-03-2007, 02:49 PM   #3
Brian VH McHale
CF Senior Member
Brian VH McHale's Avatar
try Lamptech.com
BTW I have a note that say's 1816 = 4.2 watts
1893 = 4.6 watt
Brian VH McHale is offline   Reply With Quote
Old 06-03-2007, 03:01 PM   #4
Vet65te
CF Senior Member
Vet65te's Avatar
Default Looks Like the Factory Bulbs Will Do the Job
Thanks to both for the quick responses. Looks like I'll be putting back in the original #1816s even if they have a briefer lifespan. I've only put about 3500 miles on the car since we overhauled it in '94 and the majority of that was daytime driving but there are occasions for an early morning start so it would be nice to have decent gauge illumination.
Old 06-04-2007, 08:25 AM   #5
kenEDMUNDS
CF Senior Member
kenEDMUNDS's Avatar
If you want to really light up your dash use 64111 OSRAM 5w halogen bulbs. You will be amazed at how bright your cluster is, especially the heater and a/c control bezels.
kenEDMUNDS is offline   Reply With Quote
Old 06-04-2007, 09:02 AM   #6
Vet65te
CF Senior Member
Vet65te's Avatar
Default Halogen Replacements
Quote:
Is there any issue with heat buildup using these halogens? I've always felt that the stock arrangements did a poor job of illuminating the clusters but on the flip side don't want to overtax the wiring or create too much heat in there. In my case, it seems one of the PO's grabbed whatever was available which happened to be #1893 bulbs to replace the #1816s and that coupled with dusty/grimey gauge lenses made the cluster very dim at night.
Old 06-04-2007, 10:07 AM   #7
macdarren
CF Senior Member
macdarren's Avatar
Send a message via AIM to macdarren Send a message via Skype™ to macdarren
the OSRAM bulb might need a bigger fuse, and if you did all of them I think you might be getting on the edge of the wire capacity. The other thing is they only have a 240 hour life, at 12 volts, probably less with 13+ if you have good wiring...for me that seems a bit short but if you seldom run the lights then I guess it is ok. I'm looking for some LED replacements myself.
macdarren is offline   Reply With Quote
Old 06-04-2007, 10:13 AM   #8
62Jeff
Support Corvetteforum!
62Jeff's Avatar
After what I learned in my epic search for the root of a blowing fuse in my new wiring of my 65, I had to REDUCE the candlepower of some of the dash bulbs in order to have a servicable car.
I'd never consider putting in brighter bulbs that would pull more amps.
http://forums.corvetteforum.com/show...985&highlight=
Jeff
62Jeff is online now   Reply With Quote
Old 06-04-2007, 11:24 AM   #9
Vet65te
CF Senior Member
Vet65te's Avatar
Jeff
I just read a previous post showing how the earlier midyear clusters (can't remember if it was only '63 or '63/'64) has two less dash lights. Not a big deal but still something that they 'slooooowly' got around to improving. In the case of my '66, I think the poor illumination was a combination of the incorrect #1893 bulbs instead of the slightly brighter #1816s and the dusty film on the inside of the gauge lenses.
Clean lenses and new #1816 bulbs will hopefully make it brighter at night. After reading about your extensive cluster testing due to repetitive blown fuses, I think I'll pass on using any bulbs that draw more amperage.
Old 06-04-2007, 11:37 AM   #10
kenEDMUNDS
CF Senior Member
kenEDMUNDS's Avatar
I have installed these in a dozen or so c2s with no issue at all.
Old 06-04-2007, 11:38 AM   #11
kenEDMUNDS
CF Senior Member
kenEDMUNDS's Avatar
Jeff
I followed that post closely and do not blame you for not deviating from stock. You went through a lot to solve your problem.
Old 06-04-2007, 08:21 PM   #12
62Jeff
62Jeff's Avatar
Yeah, a 63/64 had 2 fewer bulbs than a 65 in the main dash. Plus a car with A/C had 2 more bulbs as well. Yet, the circuit is a 4 amp circuit in all of those years.
So a 63 or 64 without A/C had 4 fewer bulbs than my 65 with factory A/C. Those 4 extra bulbs pull a total of 1.32 Amps if they get 12 volts to them. If I remember correctly, my circuit was about 1.30 Amps overdrawn before I put lower rated bulbs and a 5 amp fuse in place.
Good luck with whatever you do!
Reload this Page Dash Bulb Candlepower Chart?
Tags
1816, 1893, 1895, 2006, auto, automotive, bulb, bulbs, candle, candlelight, candlepower, chart, corvette, power, replace, sylvania
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
